Tool Talk Discussion Forum
Silicon spray and Oxy / Ace
Tim B from MA
05-23-2006 07:10:18
Is it saft to use silicon spray around oxy-acetylene torches.
The treads on the safety cap for the old beat up aceteylene tank they gave me in exchange are rusty an otherwise pretty "sticky".
jeffcat
05-26-2006 04:21:55
 Re: Silicon spray and Oxy / Ace in reply to Tim B from MA, 05-23-2006 07:10:18
Plain old IVORY bar soap is the best for lubin stuff. Handy, cheap,it works, and when your done you can wash up! Jeffcat
Tim B From MA
05-25-2006 11:53:15
Thanks Gents.
It's just the threads for the cylinder saftey cap that I have trouble with - I store the tanks in the wood shed (not the attached garage where I use them) so I take the saftey caps and regulators on and off frequently.
Wax or soap; sounds like the ticket.
T_Bone
05-23-2006 17:07:17
Hi Tim,
Just use a wire brush to clean the threads on both the cap and neck. If that don't still don't work too well then use wax or bar soap to lubericate the threads.
Never use any type of products on the regulators to cylinder threads.
If the cylinder threads are messed up exchange the cylinder.
If the gauge threads are messed up, buy a new gauge nut, about $5 at any welding supply.
T_Bone
Jerry/MT
05-23-2006 09:50:36
Don't use any combustible lubricant on the oxygen! It will burn. It's probably OK on the acetylene but I would take the bottle back if I were having trouble with the valve.
Bob
05-23-2006 09:49:37
Below is a link to the MSDS for ONE brand of silicone spray... in Section 5, it states "Chemical Incompatibilities & Conditions to Avoid: Isolate from strong oxidizers, oxygen...".
That would certainly seem to preclude the use of THAT product around an oxy-accetylene torch!
souNdguy
05-23-2006 07:49:55
Are you asking about propellant flamibility issues? if so.. read the can and look for flamibility warnings. Or are you trying to see if the lubricant itself is flamable / combustible... If so.. I'll bet you find that most lubes will burn.. if you force them.. but even stuff like diesel and waste oil is considered 'combustable' rather than flamable or explosive. Use a brass wire brush and clean those threads up.. spray off with a cleaner that leaves no residue.. like carb or brake cleaner.. then hit it with a dry lube.. like graphite bearing lube..e tc... ( or even a wax stick or soap stick.. I've used candle wax and soap to 'dry-lube' many things... works pretty decent too) That should keep it from collecting dust and getting gritty... just my .02$
Soundguy
