Tool Talk Discussion Forum
Small engine revisited OHV Briggs 10 hp
Jak
05-22-2006 14:49:35
I got the 10 hp ohv Briggs back together today and runs fine,they used it all day with not even a burp so far.It is on a blower with a big impeller and broke one pushrod and bent the other last week.The intake valve was stuck not sure why either but with a little PEN(penetrating oil,State Chemical)she freed up with a little tapping of a small hammer.I am trying Lucas in with the oil now hoping to avoid having a repeat.What happened???Too hot,too many rpms(don't sound like it)???Cheap metal???The boys operating when it happened won't ever tell.It was full of oil when it got to me.Whatcha think guys,and whatcha thing about Lucas?
TomTX
05-23-2006 05:17:57
 Re: Small engine revisited OHV Briggs 10 hp in reply to Jak, 05-22-2006 14:49:35
Change to Mobil 1 10W30. Fill fresh gas, with Stabil teatment. Porblem over. Tom
ErnieDD
05-23-2006 04:11:45
I am told old gas will varnish up intake valve guides. Happened to me on a Wisconsin V4.
RN
05-22-2006 16:33:13
Small engines sometimes stick valve stem when hot- one help was knurling valve guides to help oil retention/ relief of binding valve stem. RN
Bob
05-22-2006 16:00:08
Not to open another can of worms, but I've been told to use full synthetic in the OHV Briggs engines, and have had no valve or pushrod problems since switching to the synthetic oil some years ago.
Jon Hagen
05-24-2006 14:22:33
 Re: Small engine revisited OHV Briggs 10 hp in reply to Bob, 05-22-2006 16:00:08
Briggs highly recommends using synthetic multiweight oil in all their engines. If using mineral oil,they want you to use #10 below a certain temp and #30 if above. They do not like to see you use multiweight mineral oil in their air cooled engines because of the high temperature,and tell you to expect higher oil consumption if you do.
Briggs recommends and sells a fully synthetic multiweight oil for use in any temperature and any load.
Like Bob,I have used only Mobil 1 multiweight synthetic in my briggs air cooled engines for many years,and have had no engine problems and very low oil consumption,and easy starting at any temp.Some of these engines are 30 years old. I use Mobil 1 0w-30 for quick cold lubrication in the engines like pumps and generators that must start and immediatly go to full rpm and load. For engines like my 2 cyl 17 hp Briggs lawn tractor,and 4 cyl aircooled Volkswagen powered spra-coupe,I use mobil 1 #15-50 which protects those engines at high load and high temperature. Since changing it to mobil 1 oil,the Volkswagen powered spra-coupe only needs valve adjustment 1/4th as often. With synthetic oil,wear in those hot running little aircooled engines goes almost to 0.
chris cogburn
05-22-2006 15:01:10
For some interesting info on Lucas, go to www.bobistheoilguy.com and see what he did. His conclusion was basically that Lucas did nothing good, and was potentially bad. But I'm a complete hack at this sort of thing; other than that I can't help you much.
c.
oldrustycars
05-22-2006 21:22:10
 Re: Small engine revisited OHV Briggs 10 hp in reply to chris cogburn, 05-22-2006 15:01:10
bobistheoilguy says everything is bad except the crap he is trying to sell. its just an advertising site.
