Tool Talk Discussion Forum
OT Sump Pump
Bob1948
05-21-2006 16:37:35
Hello. I bought a house with a sump pump in the basement that won't work. I took it out and flushed it out with the garden hose and worked the float switch up and down. Plug it in and nothing. I was afraid to take it apart so it might not be water tight if I did so. Is there anything to repairing these things or is it nonserviceable? It is a 115 volt pump. THanks
x_ring99
05-23-2006 19:35:35
 Re: OT Sump Pump in reply to Bob1948, 05-21-2006 16:37:35
List a model number/manufacturer from nameplate.
Is it submersible or column sump pump?
If a submersible, is the float switch built in or does it "piggyback" to the pump plug? May just need a new float switch.
Roy Suomi
05-21-2006 19:27:27
So what are you doing in the mean time???? You can go to any Tractor Supply , Hardware store to buy a new pump for around $ 60.00.....I wouldn't waste my time trying to repair a sump pump..Now, if it were a grinder pump for solid effluents. They are more money , usually built better , and are readily repairable
Bob1948
05-22-2006 15:26:10
 Re: OT Sump Pump in reply to Roy Suomi, 05-21-2006 19:27:27
Thanks Roy. I figured it was probably junk but guess I was hoping for some quick fix secret everybody knew about but me. Have a good one. Bob
