Tool Talk Discussion Forum
Starting Problem with a Homelite Trimlite
Sandra
05-21-2006 15:30:43
I have got a brand new Homelite Trimlite Weedeater and am having great difficulty getting it started. I took it back to Home Depot and it started just fine by the salesman after he seemed to pull it with no problem, but I don"t have half his strength. I got it back home and could not get it started to save the life of me. I even let it rest for a couple hours, thinking I flooded it, but it still would not pull. I have used a weedeater for many many, many years and have not had this problem, just worn them out and it would be cheaper if I just bought another than to get mine serviced. It takes a lot, I mean a lot of muscle apparently to get it started that is why he started it, and I could not pull the cord out fully for it would not pull. Could you please help me?
Rockyhawaii
05-22-2006 21:11:18
 Re: Starting Problem with a Homelite Trimlite in reply to Sandra, 05-21-2006 15:30:43
If you spend a little more you can buy a Honda, they start on the second pull, every time, and it only takes two fingers. No more mixing oil and gas either. The four-stroke motor is a little heavier, but it is also runs very quietly.
Leland
05-22-2006 18:03:21
Take it back and go buy one of sears ez starts little effort required to pull rope
bbX
05-22-2006 04:16:45
Are you sqeezing the primer bulb several times before you try to start it? I have a Homelite weedeater and a Homelite leaf blower. Both start differently. Don't know about yours. The weedeater has a lever with 3 numbers on it. You put it in #1 and pull 2-3 times until it fires a time or two. Then move it to #2 and pull another couple times and it starts. Them move it to #3. I do the above with the throttle trigger squeezed and it starts pretty easily.
The blower is different and harder to start. It has a choke lever that you engage. But you do not squeeze the throttle as doing so disengages the choke. Engage the choke, then pull several times until it starts. But the pulls are harder than the weedeater. When it starts, you have to let it run for 30 seconds at idle before it is ready to run at full speed.
ezyed
05-21-2006 16:01:37
Try full throttle and full choke untell it pops then half choke . That seem to be the best for me
Sandra
05-21-2006 16:12:13
 Re: Starting Problem with a Homelite Trimlite in reply to ezyed, 05-21-2006 16:01:37
Thanks, but I just did and pulled 15 times and it would not even begin to turn over -- any other suggestions? Thanks..
Vern-MI
05-22-2006 03:06:37
 Re: Starting Problem with a Homelite Trimlite in reply to Sandra, 05-21-2006 16:12:13
You could always try a shot of starting ether in the air filter. I find that helps to start them in the spring after they sit around in storage all winter. Use just a very small shot and if it doesn't start after the first few pulls give it another small shot. The air filter element is the best place to put it as it helps to vaporize the ether into the intake of the engine. Keep in mind the ether doesn't have oil in it which is required for lubrication on the small two cycle engine. It will shorten the life of the wacker over the long run but it appears that it's useful life is about over for you anyway.
Sandra
05-22-2006 04:04:32
 Re: Starting Problem with a Homelite Trimlite in reply to Vern-MI, 05-22-2006 03:06:37
Thanks for the info, but would this still hold true if the weedeater is brand new? I just purchased and reading all of the posts on this brand of weedeater I should not be having this problem. I know Home Depot would give me (a lady) a difficult time and all of your all's help is greatly appreciated. Anything else I might try? Thank you so much
RustyFarmall
05-22-2006 04:39:36
 Re: Starting Problem with a Homelite Trimlite in reply to Sandra, 05-22-2006 04:04:32
Take it back to home Depot and have the salesman show you in detail the correct procedure for starting it, and then try it that way while you are still there with the salesman. Apparently there is a small step that you are missing, which is understandable because it seems that each brand or model of weed eater has it"s own formula for starting, and it"s difficult to diagnose without actually seeing the machine.
Vern-MI
05-22-2006 13:04:51
 Re: Starting Problem with a Homelite Trimlite in reply to RustyFarmall, 05-22-2006 04:39:36
Sorry for not reading and fully understanding your first post about it being brand new. If you are having trouble with a brand new one it will not get better with age. Do what Rusty said and bring it back to the store and have them train you on how to start it. If you still can't start it then see if they will exchange for an electric model trimmer.
These trimmers generally require a real fast snap or tug on the starter rope which gets them spinning fast to start them. You have to develop sensitivity to the exhaust so that you recognize the pop of a motor trying start. Once you hear the exhaust pop then you have to take it off choke to a secondary enrichment setting and then give it a fast tug. It should start on the secondary choke setting after first popping on full choke position. It will run on the secondary choke position until it warms up a bit then the choke can be set to off or wide open and the engine will run normally.
I don't think they would treat you worst than if you were a man. On the contrary they would seem to go out of their way to help you since they understand that these are generally hard starting devices anyway.
Sandra
05-22-2006 13:18:34
 Re: Starting Problem with a Homelite Trimlite in reply to Vern-MI, 05-22-2006 13:04:51
Thank you for all of your help, I appreciate that so very much!!
To let you all know here, I called Homelite and told them of the difficulty that I had in getting it started and they said that this year they have made their engines bigger and now they are harder to start. And thanks to you and this wonderful board, I am going to take it back to Home Depot tonight and talk with them since you confirmed that it would make no difference if I were a man or woman. I will post a follow up after I speak to them to let you all know in case these questions come up later.
Thanks again from the bottom of my heart!
