Tool Talk Discussion Forum
Automatic Compressor Drain kit
Steve-Maine
05-21-2006 02:50:39
I was looking at an automatic compressor drain kit from Harbor Freight. How do they work and are they any good? Where do you install them on tank? Thanks
kopeck
05-21-2006 12:51:26
 Re: Automatic Compressor Drain kit in reply to Steve-Maine, 05-21-2006 02:50:39
Mine worked for a little while then started leaking. I tried everything to get it to stop and never really could.
I guess for the price it would be worth a try but mine didn't pan out.
big jt
05-21-2006 07:33:59
Just looked at HF site. With my experience with Central Pnematic I would stay away.
The one that MSC has is a electronic controlled valve. Every so many minutes it purges. Don't know what controls HF's set up but with the stuff in the PIX looks to me like to many places to leak.
jm2cw
jt
big jt
05-21-2006 07:27:15
How much does HF get.
MSC has one on sale frequently for $100.
I have thought about it myself.
jt
alg
05-21-2006 06:01:46
Installed one from harbor frieght,works fine.
Eddie in MI
05-21-2006 07:49:57
 Re: Automatic Compressor Drain kit in reply to alg, 05-21-2006 06:01:46
I have the HF unit too, and so far I have had no problems.
Chris(WA)
05-21-2006 05:50:38
The drain goes on a fitting at the lowest point in the tank. Usually install an elbow and run a line out where it is easier to access. As to the Harbor Freight auto drain, you get what you pay for.Even if you do put on an auto drain install a manual drain as well. Manually draining the comperssor at night is the most reliable way go. Have seen lots of tanks with auto drains that had lots of water in them because no one ever checks them because they have an auto drain! Shut the compressor off when you are done for the day and blow her dry.
CNKS
05-21-2006 08:45:36
 Re: Automatic Compressor Drain kit in reply to Chris(WA), 05-21-2006 05:50:38
That's sort of my opinion too. Even with one you can't ignore the lines, they also need to be drained. Only advantage I see to a drain is that you leave the compressor on, thus it is always "ready". I often forget to start mine, thus I have to wait while the pressure builds up.
