Tool Talk Discussion Forum
Small engine questions.
Jak
05-19-2006 10:31:21
My job requires me to work on small engines from time to time and I have a few questions.Is the overhead valve engine that much better than the older type Briggs and Stratten,Tecumseh too?I have run across several of these overhead valve engines that have had rocker arms get out of adjustment,break retainers,bend pushrods/break pushrods,rocker arms break or fall off the valve stem.Is Briggs/Tecumseh just in the beginning of pushrod/overhead valve technology and still learning(surly not)?Parts man at NAPA said he sells several pushrods a year.This Briggs that I am working on now has aluminum pushrods????Seems like they would have made a stronger pushrod than that,they ain't as big as a pencil and not much bigger than a pocket screwdriver.It just seems like we are having lots more mechanical problems now than we used to with the old style engines.
DrewT
05-21-2006 07:58:39
 Re: Small engine questions. in reply to Jak, 05-19-2006 10:31:21
As previously mentioned, flathead engines are thermodynamically less efficient. For examples, look at the rated hp of old flathead B&S or Kohler twins vs current OHV engines of comparable displacement. Generally up around 20%.
This efficiency also translates into lower emissions per volume of fuel burned/hp generated. Given that small engine emission standards are becoming more stringent all the time, the flathead engines are being phased out.
The sorts of valvetrain problems you speak of are most likely caused by a couple things. One is poor assembly/adjustment. The other is overspeeding. Have the controls/governors on these engines been tampered with in an attempt to get more hp from them?
Valvetrain inertia and valve spring force are significant parasitic losses in engine of this size. Keep the parts light and you can use springs with low spring rates and put the hp at the crankshaft rather than the camshaft.
You may find B&S engines with one aluminum and one steel pushrod. The reason for this is that the compression release for staring the engine acts on one cam lobe or the other and is dependent on the lash of that valve train to be effective. Aluminum engine blocks expand more with temperature than steel pushrods do. So hot engine valve lash grows more with steel pushrods and diminishes the effectiveness of the compression release. Make sure the pushrods go back where they belong.
Andy
grasscutter2056
05-20-2006 18:43:45
Overhead valves are a blessing. I run a landscaping business and all of the mowers, leaf vacs,and other equipment I have is overhead. I keep extra pushrods on hand for all of the engines. They are the first line of defense for engine failure, that is why they are made of alum.
Easy to replace and adjust and only 50 cents a piece is better then two week of down time in a shop.
lucasss
05-20-2006 06:36:07
try useing honda,kawasaki or kohler engines and i think youll find the really outclass the briggs and tecumseh.. lucas
Easy
05-20-2006 04:36:48
My understanding is that small engines are designed to a Mean Time Failure number. In other words some are cheap. I think snowblower engines are the cheapest. An engine designed for a high end generator would be the other end of the spectrum. Briggs makes some really cheap engines. And they make some really good engines. But nobody makes a really good cheap engine.
Roy Suomi
05-19-2006 20:10:25
EPA makes the manufacturers build a lower emission engine...Frankly I don't see it..I don't see it burn much cleaner than a conventional type engine..On automobile engines , lots of wasted power to run overhead valve train...Seems to me the old style would use less fuel if tuned and jetted properly...Replacement engines cost dearly to buy..I'll bet manufacturing cost is 1/4 of sale price...Yeah , I know , hidden costs have to be factored in...But how many have their hand out from manufacturer to final sale...My 2 cents worth.
David - OR
05-20-2006 05:27:50
 Re: Small engine questions. in reply to Roy Suomi, 05-19-2006 20:10:25
Flathead engines have higher emissions (unburned hydrocarbons) because the large and spread out combustion chamber leads to cold spots and pockets of incomplete combustion.
Even if such an engine is "tuned and jetted properly", and even if we accept the (argueable) idea that it might use less fuel due to a less complex valvetrain, it still emits more HC per delivered horsepower-hour than an OHV engine with a better combustion chamber shape.
supergrumpy
05-19-2006 11:20:32
depends on the grade of engine you have in front of you
the big box store engines are made to sell dirt cheap, blow it up and toss it out, maybe keep it for parts
when you get into the better grades of engines then you start getting some reliabilty
you get what you pay for - my 2 cents!
