Tool Talk Discussion Forum
Electric water heater fire
Bill in TN
05-19-2006 09:13:02
I called my daughter this morning and she told me her husband was home because of an "incident". Seems the electric water heater caught on fire.....she was home and heard it pop, smelled smoke...killed the breaker and put out the fire.....no real damage.
SIL replaced the heating elements about a month ago. I've heard of gas water heaters catching on fire, but never electric.
The fire looks to have started on the upper thermostat..... .
My thinking is that an arc must have occured.....so my questions are:
Why didn't the breaker trip?
Would a GFI detected a current imbalance and tripped preventing the fire?
Replacing a heating element is a pretty simple job....now, the SIL is not dumb but do you think that the problem could have been caused by the installation of the new elements?
The condo they live in was built in the late 80's so the heater is probably of that vintage. Daughter, SIL and babies are strapped for cash but have lost confidence in this heater and want to replace it.....my thinking is that if it isn't leaking it would be much cheaper to replace the thermostats, check the wiring by removing the wires from the breaker and ohming them out at the heater.....
I've suggested that they disconnect the upper element and turn the heater on and off as required until they can afford to repair or replace the old heater. Of course, they don't have $200 to buy a new heater.....
If they hadn't been bailed out so many times before I'd loan them the money for a new heater....problem is they don't manage there money, have dug a deep hole, have bad credit, been bailed out by numerous relatives but still don't seem to learn. Throwing more money their way just makes them more dependant so SIL's father (who has bailed them out as many times as I have) and I have agreed no more money....but all the free advice they want to listen too....I guess a cold shower might be a good lesson.....but I hate it for the grandkids....Oh yea....they have a membership at the YMCA so they can shower down there..... guess I know why they stay broke.
What's do you think I should have told them as far as the water heater is concerned?
rgvtx
05-19-2006 17:32:19
 Re: Electric water heater fire in reply to Bill in TN, 05-19-2006 09:13:02
Yes, they can catch fire. You said an element was replaced? Probably the wrong element was installed, it"s happened before and will happen again. Waste money on new thermostats etc. for a 25 year old water heater? Are you kidding, that"s nuts. Most run of the mill water heaters have a 5 year warranty on the tanks, the best can be 12. Since the house is of 80"s vintage and you imagine the heater is the original, a super cheap builders model was installed so it has already lived 5 times longer than it probably should have.
My suggestion, install a new heater. Now the dilema is monday, isn"t it always. Don"t loan them any, and warn all the other relatives to use good judgement here. Let them start saving the money (should be under $200) and when they have it together buy the water heater. Meanwhile, heat water on the stove for bathing etc. Might be a real good lesson for them in the long run.
Kevin Bismark
05-19-2006 16:33:31
I guess I would lean tward just throwing it away and going with a new one,could have damaged wires where you can not see them, was this old one hooked up with greenfield, " metal flexable conduit"? without a equipment ground pulled inside, with loose lock nuts on the connectors, and what type of electrical panel do they have, is it the wonderful Federal Pacific stab lock breaker panel, with breakers that don't trip. Hard to know for sure without being able to see it with my own eyes, just when I think I have seen it all, something tops it all, would go on and tell you what I found yesterday, but it has me too mad to think that could ever have been done..
Kevin
Bus Driver
05-19-2006 15:09:44
Charles Dickens Quotes:
"Annual income twenty pounds, annual expenditure nineteen nineteen six, result happiness. Annual income twenty pounds, annual expenditure twenty pounds ought and six, result misery."
frankiee
05-19-2006 12:53:18
Kids are mentioned so I think the heater has to be disabled or replaced.
A poor connection could have caused that or other things but what is important is the heater should be considered junk. For peace of mind do not think of the son in law and daughter but think of the babies.
If I were in that position I would put a new heater in and have them sign a contract and take them to court if they did not agree to it.
Let them know that there is more at risk then just themselves.
Don't play with old deteriorated rusted wire in a heater. Throw it out. Its a safety thing.
I know its their place and their call but you could lead them to water and see if they accept.
I know they have to live and learn but here is where the experience of life comes in. There can not be deadly fires happening in that house.
I think of what you would feel if anything happened and you felt you could have done something before hand.
Let them lose the care the ... and the .... and the ... but if it comes to the safety of the grand kids I would pay for it and make them honor the bill.
Let them know the only reason you are doing it is for the kids.
The way I see it any hows
Stan in Oly, WA
05-19-2006 11:12:45
Hi Bill,
There's no way to know whether your SIL made a mistake installing the new thermostat but I'll bet that an insurance claims adjustor would think so. Twenty years of normal service followed by a fire a month after a non-electrician replaces thermostats makes a strong circumstantial case.
There's not much to burn at the thermostat of a water heater. Usually there's a flap of fiberglass insulation covering each thermostat behind each access panel. The main insulation of the heater is usually cut back as far as the edges of the opening. Newer heaters have foam insulation under the shell but one from the late 80's might have fiberglass. The only thing to burn there is the insulation on the wires.
I'm getting outside my area of competence to speculate on problems of electrical connections and shorts, but since there are several expert electricians who read and respond on this forum who will politely correct me if I'm wrong, I'll go ahead. A short is a line to ground contact; it trips the breaker because the ground has the capacity to draw unlimited current. But appliances can also arc at a loose connection or a discontinuity in the line. This will not trip the breaker because the amount of current causing the arc is correct for the line. I don't know enough about why GFIC's work the way they do to say whether non-short arcing would cause one to trip. My guess is that it wouldn't.
Every electrician has seen instances of damage done by arcing. The most frequent is probably at the electrical service panel where the aluminum cables from the meter base are lugged into the panel. The expansion/contraction of the aluminum loosens the connection, or the lack of anti-oxidizing compound allows the aluminum to corrode until it's no longer a tight fit. Fires start because of that arcing.
Proper installation of new thermostats should solve the water heater problem, but I'm not surprised that your daughter and SIL aren't comfortable with that answer. Besides, the water heater is twenty years old. There's no way to say how much more service it's likely to provide. And new ones are more efficient, anyway.
Here's some advice you didn't ask for. I absolutely guarantee it's worth at least as much as it costs you. You and your SIL's parents buy the kids a new water heater with the understanding that it represents the next birthday present from each of you to each of them. That's about $50 per person per b-day, and it's a pretty good present, under the circumstances.
All the best, Stan
steveormary
05-19-2006 10:14:50
Bill in TN;
Dont really know what to say. We do alot for our grownup children Our son is 33 and we have bailed him out several times. Sure cut into our retirement. Now we have helped him start a business and LO and BEHOLD,he is paying us back.
It might be because we threaten to move in with him when we go broke.
Now about the water heater. I think replace the thermostat and element and go from there.
Also,make sure the water heater tank is full and you have water comming out the faucets before you turn the heater on. Otherwise you lose the element.
Whereabouts do you live in TN. I have some distant cousins around Luttrell and Coryton.
steveormary
Jak
05-19-2006 10:10:08
Hey Bill I had an electric water heater 50 gallon that was only a couple of months old catch fire and it didn't trip the breaker either.It extinguished itself thank goodness but it could have been bad.For the grandkids I would probably help them but there are so many people out there just like you described that will keep using you as long as they can and you will let them.Sounds like a rock and a hard place.Jack(TN).
Easy
05-19-2006 10:06:18
3 things - JMHO:
1) Electric heaters can catch fire. My neifghbor's did in the mid 90's. Totaled the house.
2) .... advice is cheap, ( none cheaper than here!) but do the kids have a plan? What is the situation? Is it a failure to plan or a deeper problem? A lot of young families are stressed these days. Jobs paying enough to raise your grandkids are hard to come by. Before you decide what to do, maybe a regular meeting and discussion of thier situaation is in order? The most sucessful families I have seen, are the best communicators.
3) 20 years is a long time for a water heater. I have replaced mine 2 times in 21 years.
BBx
05-19-2006 10:05:41
I would have two guesses.
1. Incorrect heating element. If it was drawing more current that what the thermostat was designed for, it could overheat the thermostat without tripping the breaker.
2. Wiring not properly tightened. A loose wire at high current will overheat at the bad connection, even at normal current draw.
Bill in TN
05-19-2006 12:17:38
 Re: Electric water heater fire in reply to BBx, 05-19-2006 10:05:41
There plan is to replace the water heater in a couple of weeks when they get their next pay check. I've got to say, there pretty good kids for the most part. He has a pretty good high tech sales job and the makes pretty good money.
They just do things that don't make sense like take a vacation instead of paying there mortage payment....they try to live beyond there means and they are both a little self centered.....
Grand father and mother bailed them out first to the tune of $20,000...paid off car payments and credit cards and were to be paid back interest free at $400 a month. They paid 3 payments then went and traded cars.....on credit of course..... .This created a situation where my daughter, who was very close to her grand parents, wouldn't go visit although they never asked about the money. Then there were laptop computers and guitars.....cameras.....etc.....next thing you know, they were behind 4 months on the house payment which is lower than apartment rent. They had been in the place for 9 months and SIL's father had made 5 of the payments..... ..I found out about this after they took a long trip out of state to visit friends and family while the brand new laptop was sitting on my kitchen table. First the car got repoed.....so they bought another one at one of the no money down, buy here pay here places and not only bought a more expensive car, but are paying about 26% interest for it. That's when FIL who was down for a visit suggested we go for a gallon of milk and we started compairing notes..... seems him and I were paying all their bills, clothing the babies etc. while they enjoyed life to the fullest....The ex wife paid to fix the air conditioning..... seems every relative who would "loan" them money had a story.....
They started using the check into cash service borrowing $200 dollars....well, next payday they had to pay back $225 and borrow $200 again....I'm not exactly sure how this works but they kept getting farther into this scam.....at the same time, bouncing checks, or ATM...for a pack of cigs and a coke.....$29 dollar bounce check fee and $25 dollar merchants fee..over a $5 dollar purchase..... so back to check into cash they go..... finally didn't pay a hand written $9 check to walmart who took them to court.....
That was the best thing that could have happened to them..... Judge said go to Dave Ramsey's money course or go to jail....For those that don't know, Dave Ramsey is a christian based syndicated radio talk show host that teaches how to handle money among other things.....
I won't go into how much money I've given them....
Either way, to me it's like giving a drug addict more of the drugs.....it makes him feel better but it doesn't change behavior. It makes them feel good for awhile but the results are more of the same.
I could go down to homer depot and buy a new heater.....haul it over there and put it in for him but would they learn anything?
My dad told me you can learn the easy way or the hard way.....I've explained the way things work....told them don't worry about toys....and security is the best gift you can give your children but every little thing is a financial disaster for them.....
I love them both.....but until they learn, they will always be a slave to the lender.....I really hate to point it out but do try to point out that the reason for saving money is for times like these.
Credit, and debt is the most aggressively marketed product of any and it's a huge trap for our children....buy now pay later..... ..I really want them to learn to avoid the trap and have financial freedom and the piece of mind that goes with it.
I have other children and I feel guilty when I do for one and not the others.....
My feelings are they were given a chance the easy way....that hasn't worked....so....guess it's cold showers.....
Freeloader Frank
05-19-2006 16:55:28
 Re: Electric water heater fire in reply to Bill in TN, 05-19-2006 12:17:38
Sounds like people have been enabling them for years. I have a BIL like that. Always minutes away from having his house repossesed. I found out the wife made a house payment for him once. I didn't consider it a loan because that would mean I would have a chance of getting it back. I told her if she ever did it again she would be living with her brother. I've listened to all the whiny stories. Kids need food, bank is going to sue, car needs fixing etc. I told her " tough schmidt".
He is healthy but just lazy. If he chooses not to work then let him starve.
He has been like this since I have known him. About 20 years or so. If someone would have been tough on him years ago he may have changed then.
If your "kids" have to take a cold shower for awhile, maybe they will decide they can give up some other luxury to pay for a necessity.
