Tool Talk Discussion Forum
Steel roof coating
Heritage
05-15-2006 19:05:06
I have two steel roofs that need coating. The paint on one is gone but the steel is galvanized and has no rust. The other is galvanized steel with nail holes from a prior installation with some sheets rusty. What kind of coatings should I use?
John A.
05-16-2006 17:38:57
 Re: Steel roof coating in reply to Heritage, 05-15-2006 19:05:06
Heritage, I have save 2 roofs from being replaced. Both were 70 + yrs old, corrigated sheet iron.
We used "Monsey" standard grade Aluminum roof coating. This stuff is an emulsion of aluminum particals, short strands of fiber in a petroleum base. Open the 5 gal bucket, and it is jet black, Then take an electric drill and a stirer and watch this stuff turm bright aluminum color, Use a large, course 10 in. brush, or short bristle broom of a thing. The paint supplier can recomend something they have.
Then start at the top and work your way over and down. Only pulling the paint in one direction. The fibers will fill in low spots, cracks, holes and other imperfections.
These roofs have finely looked like they need a recoat in the last year or two, can see little hints of the rust underneath. OBTW...one roof was total rust, no galvanize left at all. This coating has lasted 10 yrs, a recoat and they should go another 10. Hope this Helps!
Later,
John A.
Bus Driver
05-16-2006 04:08:02
Many of the white acrylic roof coatings are not suitable for application directly over rust. But the acrylics should be the longest lasting.
Jim Broughton
05-15-2006 20:25:23
Go to Home Depot and get that "Snow-Roof" coating, especially for the used galvanized roof, heck, that stuff will covera 1/4 inch hole in the roof!! It's a little spendy, but you won't be repainting for 15 or 20 years !! (Get the white colored one) Lotsa luck! Jim
onefarmer
05-16-2006 19:07:48
 Re: Steel roof coating in reply to Jim Broughton, 05-15-2006 20:25:23
I went to HD and didn't find "snow roof". Are you talking about the stuff in the roofing section. They had something called cold coat. Is this it?
Nolan
05-17-2006 04:48:16
 Re: Steel roof coating in reply to onefarmer, 05-16-2006 19:07:48
third party image
Ace Hardware has it.
onefarmer
05-17-2006 12:33:16
 Re: Steel roof coating in reply to Nolan, 05-17-2006 04:48:16
Thanks!! I will be checking it out.
