Tool Talk Discussion Forum
Tapping cast iron..with or without oil?
used to be jame
05-09-2006 18:44:57
Maybe this is not important, but it seems like I remember being told in High School that cast iron should be tapped without oil? Is that true?
I need to tap some threads in my JD carburetor.
Thanks,
James
MikeCatthemuseum
05-10-2006 16:16:38
 Re: Tapping cast iron..with or without oil? in reply to used to be james, 05-09-2006 18:44:57
No need for oil. Tapping cast iron is nearly like tapping soapstone. You don't even usually have to back up to clear the chips. It'll just crunch right through. As long as the tap is reasonably sharp you won't have any trouble.
Bus Driver
05-10-2006 14:55:33
I do agree that machining of cast iron is typically done dry. But my experience shows that tapping with a lube is much easier. Why not use a piece of scrap cast iron and try it for yourself both ways? The Marvel Mystery oil really makes tapping easy.
captaink
05-10-2006 12:00:17
In college my machine shop instructor said that cast needs to be machined dry. If I remember correctly the oil and the carbon react to make the metal harder, and more difficult to machine. Of course, your carburetor may already be oil soaked, and harder to machine.
soundguy
05-10-2006 07:20:20
I've always tapped with grease rubbed into the tap, especially on the flutes. This not only lubes.. but catches the chips to keep them out of special plages.. like gearboxes and carb venturi's..
Soundguy
Easy
05-10-2006 06:38:18
I think Tap Magic is great stuff, but I have also used crisco, or liquid soap. I have seen some machining of cast iron done dry, but not tapping. Just about any oil will help, the slippier the better.
joe fabregas
05-10-2006 04:54:56
Usually dry, your tooling is lubricated by the carbon in the cast iron. joe in ny
Oliver Power
05-11-2006 04:13:15
 Re: Tapping cast iron..with or without oil? in reply to joe fabregas, 05-10-2006 04:54:56
Yes Joe , you are correct.
Bus Driver
05-10-2006 04:19:39
Marvel Mystery oil works well for me.
msb
05-09-2006 20:37:23
Carbon tetrachloride will do it and won't cause problems if you have an old fire extingusher filled with carbon tet.
dan hill
05-13-2006 02:37:26
 Re: Tapping cast iron..with or without oil? in reply to msb, 05-09-2006 20:37:23
Carbon tet is bad news, dont use it.
Davis In SC
05-09-2006 19:44:14
I use oil, when tapping cast iron. I think there are 2 reasons that folks say not to use oil when doing any machining on CI. First is, that fine dust-like chips make a mess mixed with oil. Second, oils soaks in CI, & causes problems if part is to be painted. I recommend using Tap-Magic, or a similar product, but any oil is better than none, IMHO....
BigMarv1085
05-10-2006 06:11:47
 Re: Tapping cast iron..with or without oil? in reply to Davis In SC, 05-09-2006 19:44:14
I was reading in the back of a drill guide chart and it said used crisco for tapping cast iron
