Tool Talk Discussion Forum
Phone wiring protocol
jCarroll
05-08-2006 15:29:58
Our phone company uses red/green for line 1, yellow/black for line 2, and so on.
On line 2, is the yellow wire the "red substitute" or the "green substitute" ?
Can I check an unknown pair with a VOM to determine tip and ring?
Thanks
jCarroll
05-08-2006 19:01:03
 Re: Phone wiring protocol in reply to jCarroll, 05-08-2006 15:29:58
Thanks, guys!
Tractor buds know everything!
Ralph - Ohio
05-08-2006 16:05:09
"Can I check an unknown pair with a VOM to determine tip and ring?"
With a DC voltmeter you should see approx. 48 volts "talk battery" on each pair coming from the Telco central office. You can compare a known good pair with an unknown one. I don't remember which way the polarity is but I think tip is positive.
RandyBee
05-08-2006 18:04:08
 Re: Phone wiring protocol in reply to Ralph - Ohio, 05-08-2006 16:05:09
Tip is positive and ring is negative. Tip is grounded at the central office. Pair 1 tip - green ring - red
Pair 2 tip - Black ring - yellow
Ralph - Ohio
05-08-2006 15:56:53
Green & black are tips, red & yellow are rings. With most modern, electronic phones tip and ring don't matter anymore. Party line phones are a different story.
upred
05-08-2006 20:40:04
 Re: Phone wiring protocol in reply to Ralph - Ohio, 05-08-2006 15:56:53
Red, green, yellow, black, Or RGBY wire. If you are trying to run two dial tones over RGBY there is a good possiblity of Crosstalk between the pairs ( ie Phone on rg , computer or fax on yb,). I have had crosstalk happen over as little as 5 ft of rgby wire. The rgby wire was not designed for two dial tones. You may have to upgrade your wire at least cat 3. Cat three wire is twisted as are the telco service drops, cables, cross connects, and frame wire, this is all done to eliminate crosstalk on the network.
With cat 3 and above white/blue is tip, Blue is ring, orange/white is tip and orange is ring.
Just an FYI
Rick AT&T Cable repairman
