Amplifying on this further - You will want to put ball valves on each side of your filter. This allows you to change the element without draining the whole system and/or making a mess. It also limits the amount of air that enters the system at change-out time. For extra credit, add a bypass line and a third valve so you can run without the filter for whatever reason. I never like to put valves or filters ahead of the pressure switch. As was mentioned, a blocked filter or inadevertantly closed valve can create a situation where the pump is dead-headed. Since pressure never comes up in the tank, the pump runs and runs and runs. Depending on the sizing of the pump, it may create enough pressure while deadheaded to blow out the piping in the well or from the well (particularly common with poly pipe), or to blow up the filter housing. Alternatively, a lower pressure pump may stay within the pressure ratings, but now it is operating with no water flow through the pump to carry away heat from the motor, thus damaging the pump. The pressure switch should be mounted right at the tank for best operation. Thus, the filter will be downstream from both the tank and pressure switch if you want to avoid this potential problem.
