Tool Talk Discussion Forum
Stoker or Batch Fed
Oliver Power
05-07-2006 06:28:49
First off , My Congratulation to Midwest Redneck in his corn stove purchase. I"ll bet your glad that"s over with. We were side by side for a while. Now it"s time I make my move. I"m down to 2 boilers. The "Harman" model SF-160 (Batch Fed) , and the "Keystoker" model KAA-2 (Stoker fed). I have local dealer and coal for each. Which would you choose , and why?
RB/CT
05-07-2006 14:03:16
 Re: Stoker or Batch Fed in reply to Oliver Power, 05-07-2006 06:28:49
Stoker would probably be adjustable from 5 to 70 thousand btus. Dont know about batch fed. I use a Alaska Stoker Stove, (also fromPA), www.alaskastove.com. As far as maintainance, gear motor has a ten year warranty, clean it once a year, and make sure gaskets are in place, and little holes in the fire area clear. Good luck.
buickanddeere
05-07-2006 07:13:19
Stoker. A little more maintaince a couple of times a year. However you can leave for a few days and run on the coal stored in the hopper. Keps the house form getting cold if the Mrs. doesn't want to get her hands dirty while you are away. You can also mix a little grain or wood pellets with the coal if you want to.
