Tool Talk Discussion Forum
U.S. General air compressor
Don L C
05-04-2006 08:49:13
HI ---
I need to replace my shop air compressor----
Harber Fraight has one on sale for $699.99..
U.S. General --- Industry guallity ---
Lot #93274, 60 gallon, 165 PSI, 2 stage--
230 V, 5 HP rated motor
Air delivery: 13.5 CFM @165#, 15.8 CFM @ 90 PSI
16.4 CFM @ 40 PSI
Cast iron cylinders with stainless valves...
auto. start and stop...
ASME tank with safety valve...
No mag start required...
What do you think I don't get in the shop much, but when I do I want air to run air tools...
Air wrenches; DA; saw; Paint gun ....
Lee Aanderud
05-08-2006 18:26:47
 Re: U.S. General air compressor in reply to Don L C, 05-04-2006 08:49:13
It'll do fine. I've got the single stage version and it keeps up with my blasting booth just fine... if it can run that it shouldn't have any problem with a DA or grinder.
neblinc
05-05-2006 06:35:17
If you have a retail store close by, here is a 10% off coupon.Sometimes they have 20% off coupons.
Randy
XRogerX
05-04-2006 16:38:56
It'll do ok. You probably won't run a d/a sander with it though, or any large grinder. I'd be suspicious of not needing a mag starter, this one is right on the ragged edge in terms of the kind of power draw a pressure switch will comfortably handle.
