Tool Talk Discussion Forum
Design question
Fawteen
05-04-2006 01:56:52
I'm considering building a hydraulic thumb for my mini-backhoe. The ones I've seen on the big rigs will pull right up against the dipperstick when fully retracted so as not to be in the way when not in use.
My question: How does one go about figuring out attachment points and ram stroke to get full travel without binding?
Errin OH
05-04-2006 08:20:08
 Re: Design question in reply to Fawteen, 05-04-2006 01:56:52
Templates. Get you some plywood/press board and clamps. Much easier to make changes before mounting and cutting up steal. I built a complete backhoe that way. Constructed the whole thing (boom part) out of 2x's and 1/8 plywood. For cylinders I took 2 sizes of PVC and duplicated the stroke. Had it mounted to the back wall of the garage. When done, pulled it apart and cut out all the pieces to assemble. Only had one mod in all of it (missed measured one cylinder).
Bret4207
05-04-2006 03:55:30
Link
Take a look at the link above. Lotsa homebuilt thumbs and such.
T_Bone
05-04-2006 03:30:37
Hi Fawteen,
Probably the easyist is to copy a working unit. If your not selling the unit then there's not usually a problem.
If not, then graph paper and a compass working close to scale as possible and use swing arcs to prove your design.
Once the paper model proves it's self, then use some 1/8"x1" flat bar and 1/4" bolts to make a real size model on the unit to confirm your deminsions. Once that works out, then it's time to build the real McCoy :)
$25 worth of scrap flat bar is really cheap when comparred to $300 worth of good steel with a mistake.
T_Bone
Chris(WA)
05-04-2006 03:13:51
Go find one on a machine and take lots of pics and measurements. Inventing the wheel was hard, copying it was what the next guy did!
