Tool Talk Discussion Forum
Looking for a tool
Dan-IA
05-02-2006 22:03:48
I'm working on a White 4-150 with hydraulics that seem to _barely_ work when the engine is running. The pump is fine--it is even getting hot from trying to pump the oil.
Well, long story short... Local mechanic says I need to pull out one of those plugs. But I need some really big 14mm-or-so 6-sided allen wrench to remove it. Can't seem to find anything close up here.
I've tried to find a matching bolt that fits, but I can't seem to get a good enough pair of pliers on it to get the plug to turn. (The handle on a big cold chisel is close, but those are 8-sided, not 6.)
big jt
05-05-2006 08:44:49
 Re: Looking for a tool in reply to Dan-IA, 05-02-2006 22:03:48
Weld a handle on the bolt.
jt
JiminIA
05-03-2006 11:11:52
I have had good luck using the chisel and the double nutted bolt as said before....Jim
Slowpoke
05-03-2006 01:36:47
Take a 9/16" Allen wrench and carefully file a few strokes off of each flat about 3/8" long on the end. You'll only need to remove about .005-.006 from each flat. Pick up a replacement at the flea market. No 9/16 Allen? Use a long bolt with a head of the right size, heat and bend at a right angle about an inch out. No bolt? Use a short 9/16 hex shaft filed to fit and a 9/16 box wrench. NO PLIERS!
IHC Red
05-03-2006 00:35:56
You could try a short 3/8" bolt... double nut and tighten the nuts to each other. It might fit into the hole. 9/16" is 11 thousands larger than 14mm. You can then use a 9/16" socket or wrench if there's enough slop in the hole.
Or find a metric bolt and nuts that fit a 14mm wrench and try this if the 9/16" bolt head is too big.
Dan-IA
05-03-2006 10:49:39
 Re: Looking for a tool in reply to IHC Red, 05-03-2006 00:35:56
Thanks!
Caliper reading is .550 inch across the plug. Took your suggestions, with a small change. 3/8 bolt, double nutted, shaved about .010 inch off each flat, tapped in gently with a hammer. The plug came out much easier than I expected!
Glad I had a couple buckets handy, I would've lost all 7 gallons of oil!
Mike Burdick
05-02-2006 22:31:38
MSC Industrial sells a 14mm hex key.
