Tool Talk Discussion Forum
O/T professional house painters
Rob NC
05-02-2006 18:26:59
I'm about to paint a bathroom in my house and would like your advice about the best paint to use. oil or water base. which would least likely to blister in the long run especially on the ceiling. i have some minor blisters now over the shower area but i will be sanding those out. this is not sheetrock, it is plaster. thanks
Lee Aanderud
05-08-2006 18:29:37
 Re: O/T professional house painters in reply to Rob NC, 05-02-2006 18:26:59
I've painted my entire house with Lowe's Valspar paint and not had a problem. I did the bathrooms and kitchen in the Latex semi-gloss with no problems.
IA Roy
05-03-2006 12:37:21
My DIL works at the depot (drives 30 miles) and used a lot of Behr in their remodel project. She ran short and got some True Value (4 block drive)and said it compared very well.
midwest redneck
05-03-2006 02:24:56
Home depot and other stores sell a bathroom paint that holds up to the moisture. As far as primer, I dunno.
Rob NC
05-03-2006 03:34:20
 Re: O/T professional house painters in reply to midwest redneck, 05-03-2006 02:24:56
Is the quality of the paint from HD or Lowes as good as that from a regular paint store like Sherwin-Williams etc.etc.?
Tim B From MA
05-03-2006 19:36:43
 Re: O/T professional house painters in reply to Rob NC, 05-03-2006 03:34:20
In my opinion the Home Chepo brand (Behr, correct?) and the Lowes Brand (Valspar ??) are crap, and are to be avoided. Home Chepo brand latex to paint my kid's room a few years ago - two coats and you could still see through it and the stuff was so thin and soupy it would run for about 15 minutes after cutting the corners with a brush.
I brought back what was left and demanded a decent brand for replacement - Glidden worked fine.
We used to always use Benjamin Moore from the regionally famous Spags department store - but with the advent of the big box store and "just in time deliver retail" (which means if you didn't buy it the season BEFORE you need it, you are SOL) they went the way of the dodo bird.
Slowpoke
05-07-2006 00:21:13
 Re: O/T professional house painters in reply to Tim B From MA, 05-03-2006 19:36:43
Both brands have been around for years before Home Depot and Lowes started business.
midwest redneck
05-03-2006 08:17:37
You have to buy a good brand like Behr.
ErnieDD
05-02-2006 18:50:43
Oil primer, 2 coats on bare plaster.
MILDEW PROOF for top coat.
Exhaust fan.
