Tool Talk Discussion Forum
bearings
ricedaddy
05-02-2006 18:19:23
Does anyone have a book that you can take a cat bearing number and get the fafnir, bower,timken numbers?I need bearing # 4B8108 and the race is 4B8107. Thanks in advance
[email protected]
markct
05-05-2006 20:25:23
 Re: bearings in reply to ricedaddy, 05-02-2006 18:19:23
napa should be able to cross them, i know they can for seals atleast, i had a few seals from my caterpillar grader and took them in expecting to measure and match them up, the guy looked at the cat number and put it in the computer and brought me out a CR seal that was the same size
kidbob
05-03-2006 09:11:45
My book says the 4B8108 is SKF BU1209 and 4B8107 is SKF 1209ZA. Hope this helpes.
steve-Maine
05-03-2006 03:31:12
Try Motion Industries, if there is one near you. They can usually cross about any brand bearing and seals. good Luck
XRogerX
05-02-2006 19:24:03
This might help. It will give you NSK and RHP numbers from a cross referenced bearing from other manufacturers
NC Wayne
05-02-2006 19:20:10
We've got an older Bearing Bible that crosses just about all of the "brand" names like Timken, Bower, etc but I've never seen one that gives crosses for CAT numbers. That would make things way to easy.... If you get me the dimensions though I can look them up that way with no problem. Give me the ID and thickness/height of the cone and the OD and thickness/height of the cup and any special things like a snap ring groove on the cup, etc. With these dimensions it shouldn't be a problem to find what you want. One thing though, depending on what their in CAT has been known to have special bearings made just for the that are slightly off what you can readily get just so you have to get them from them.
