Tool Talk Discussion Forum
Kohler K321 in wheelhorse, charging problem
Mike from cny
04-29-2006 18:56:09
Havin problems with my antique lawnmower tractor, A 1971 GT-14 wheelhorse. It charges okay if theres no other electrical load. However it has a electric pto clutch to run the blades, and it will only last about an hour on a good charge before the clutch doesnt have enough voltage and the blades stop. Not realy familier with this at all, does anyone know how to test a voltage regulator? This has a small aluminum finned box with 3 spade connectors coming out of it. My only other guess is the PTO clutch is drawing too much for the 'alternator' underneath the fly wheel to keep up with. Any ideas? Thanks
Bret4207
05-01-2006 04:23:57
 Re: Kohler K321 in wheelhorse, charging problem in reply to Mike from cny, 04-29-2006 18:56:09
Do the Briggs system work in more or less the same way? I have 2 that don't charge.
Bob
05-01-2006 07:44:34
 Re: Kohler K321 in wheelhorse, charging problem in reply to Bret4207, 05-01-2006 04:23:57
It depends upon the model. Some simply have a single diode, other (usually "bigger") units have a rectifier/regulator like the Kohlers.
Mike from cny
04-30-2006 20:08:10
I got the rectifier out and all cleaned up, the output side of the recifier wire broke off the ignition switch, gonna order up a new switch, just ran the rect. wire to the Pos side of the battery, worked great all day and still fires right back up. Thanks again guys!
Ralph - Ohio
04-30-2006 04:55:13
A very common problem on these charging systems is a poor ground between the aluminum rectifier box that you describe and the frame. Try removing the screws and cleaning the contact areas. Frequently a user will replace the rectifier and the problem goes away just because the screws were corroded or rusty but the original rectifier wasn't bad at all - just not making good contact.
Bob
04-29-2006 19:03:12
With the connector off of the regulator, and engine revved a bit, there should be 25 to 28 Volts AC on the outer terminals. Stop the engine, and put the connector back on, and start it again. There should be somewhat over 14 Volts on the middle terminal on the regulator, and about the same at the battery. Typically, the current from that middle terminal passes through the ignition switch on it's way to the battery, so a bad switch, or dirty terminals at the switch can prevent charging.
Here's a link to the Kohler manual, which has a section on the charging system, on-line:
Tim B From MA
04-29-2006 19:54:02
 Re: Kohler K321 in wheelhorse, charging problem in reply to Bob, 04-29-2006 19:03:12
Good post Bob. I am having a similar problem with a Kohler CV20 engine that I just bought a new regulator/rectifier for - but the amp meter on the machine still shows about -0.5 amps when the engine is running, and about -7 amps when the mower deck (electric clutch driven) is engaged. I will take a look at the ingnition next.
