Tool Talk Discussion Forum
20# PSI
CH (upstate NY)
04-28-2006 16:38:47
Anybody know the PSI rating of a 20# propane cylinder. I'm building a new pole barn and only have 120 volts available. Can't use my big compressor for my framing nailer and don't want my little Makita running forever. Figured I'd purge my old 20 pounders and use them for more air capacity.
Thanks, Charlie
51Pony
05-06-2006 04:12:16
 Re: 20# PSI in reply to CH (upstate NY), 04-28-2006 16:38:47
Hey Hawk,
Come on up the hill and eyeball one! An old refrigeration compressor and a propane tank. Wife's scared of it so it helps keep her out of the shop.
Pooh Bear
04-30-2006 23:25:50
Our first air compressor was a water heater tank
and a pancake compressor out of an old refridgerator.
Slow to pump up but it is good up to 125#.
Put an electric pressure switch on it and a pop-off safety valve.
This setup runs off 110 power and is very quiet.
A friend of ours used a setup like this for many years.
Our next compressor was a large commercial refridgeration
compressor and an 80 gallon propane tank.
This compressor was more like a regular compressor.
It had a compressor head driven via belts and pulley from a 220 motor.
Used this setup for quite a few years.
Then got a big Sears Craftsman compressor.
Had this one for close to 30 years now.
25 gallon tank 5 hp motor.
Rebuilt the compressor head a few years back
and it runs like new. I expect another 30 years out of it.
I used to have a 1970 F350 dump truck. One year I had to put a new (used) motor in it. I got a motor out of a 79 Lincoln Mark V. It came with an air conditioning compressor. I went to a big truck junkyard and got an auxillary air tank for air brakes. I mounted the tank under the bed of my truck and plumbed it to the compressor. Ran a guage up into the cab an added an electric pressure switch. When it reached 100# it shut off the electric clutch on the compressor. I used a toggle switch to manually shut it off. Put a safety pop-off valve on the tank and a quick-connect to hook up air hoses to it. Worked great for years for me. Used it a lot for airing up tires. Ran an air drill, air ratchet, etc.
I sold the truck about 5 years ago. I still see it sometimes. It has my setup still on it and it all still works great.
Pooh Bear
Bob - MI
04-30-2006 09:32:04
I am doing the same thing. Propane guy told me it"s over 200PSI rating for one of the 20# tanks.
I have a small compressor tank and I want to get more storage as well. The thread in the top of the tank is 3/4 npt. I am planning on mounting 4 of them up in the rafters of my pole barn. I am also planning on putting a drain in the manifold lines that will run to the tanks. Tanks will be upside down so they will drain well.
I would be interested in what you are planning for your setup.
Thanks
Paul Janke
04-30-2006 07:04:20
I don't know about the bottles, but the tanks are rated 650 PSI at 250 degrees and 250 PSI at 650 degrees. If I am wrong (this is from 15 years ago) somebody will probably let us know.
Oliver Power
04-30-2006 05:31:12
I have a 20 pound propane tank which I use as a air tank. Bought an air tank kit , which screws on to the top of the tank. Kit has spot for filling , shutting off , and air hose. Not sure about max pounds , but I put in 100 pounds all the time.
oldfarmtractor
04-30-2006 05:07:44
Rent on of those nailers that use propane. No cord, no airhose. Every single person that I have talk to who own one loves them. I don't think a single one of them would ever go back to carrying a "tail" anymore.
souNdguy
04-29-2006 22:23:22
Wallmart sells CH air-up tanks in the 10g to 15g range. i added one to my 4g/2hp pancake compressor so I could run small air tools from it.. worked good. Thos tanks are pretty cheap.. I have seen them for 10bucks and they have a gauge on them. probably cheaper to buy the correct tank than the ends to convert a gas line to air.. plus you won't have to guess either..
Soundguy
4010guy
04-29-2006 07:55:16
hey i know this is gona go over like a lead baloon but around some parts of the country thear are people that run thear air tools off of vapor on thear propain tanks.....(do it out side and DONT SMOKE) lol
Davis In SC
04-30-2006 17:07:07
 Re: 20# PSI in reply to 4010guy, 04-29-2006 07:55:16
One spark, & it might launch a hot-air balloon... I have also heard of folks using propane for tools, but it scares the heck out of me...
old
04-28-2006 17:10:53
Most tanks are peasure tested to 300PSI. Not saying that is what it can hold but just tested at the so 120PSI you should be ok. I've seen a lot of them used as protable air tanks
