Tool Talk Discussion Forum
Tool, what is it?
charlie2pop
04-25-2006 20:01:47
third party image
Guys help me out here, here is a tool I dont have any idea what it is used for or how to use it, but I am lucky enough to have 2 of them, it is made by Black Bros Co. in Illinois. Any ideas? Thanks Charlie2pop
Coldiron
04-30-2006 13:12:35
 Re: Tool, what is it? in reply to charlie2pop, 04-25-2006 20:01:47
It might be a device that was used to tighten wooden pipes before the final bands were put on. If the joints weren`t really tight they would need to be squeezed up more. I am assuming the handle is threaded to the chain.
Dan in Ore
04-28-2006 03:57:38
Looks like an elastractor for Oregon calves. Someone will know what I'm talking about.
Dan
Nolan
04-27-2006 11:30:55
I rather suspect that was used by the company to lift their veneer/laminate rollers when they would change them on the machines.
lucasss
04-27-2006 11:36:21
 Re: Tool, what is it? in reply to Nolan, 04-27-2006 11:30:55
used one once when i hurt my back to go to the bathroom.,wasnt supposed to lift over 25 pounds..
Jest'a thought...
04-27-2006 17:08:20
 Re: Tool, what is it? in reply to lucasss, 04-27-2006 11:36:21
Ifen you installed indeer plumben, you wouldn't have to heist that bucket up over the wind'er sill every time. Save on yer back a heap...25 pounds is a lot'a nightsoil at one time.
lucasss
04-28-2006 19:17:32
 Re: Tool, what is it? in reply to Jest'a thought..., 04-27-2006 17:08:20
it wasnt the bucket i need help liftin... lmao..... lucas
charlie2pop
04-26-2006 21:33:15
I am thinking like you guys its for a round object to draw it tight and the way its made you could use another chain and go as big as need be
thanks for all the replys
Davis In SC
04-26-2006 18:28:30
Rauville is right, about Black Bros. I did a web search, & found the site. That tool looks like it could be handy for holding or binding things down... Should be useful.. I often find a use for things I happen to have...
Arthur
04-26-2006 08:47:36
It's a chain with a dohicky on the end of it...Yer welcome
RandyBee
04-26-2006 07:59:30
It looks like is made to wrap around a log to pull or move in place.
Rauville
04-26-2006 05:48:58
Can't tell you what the tool is used for, other than to guess it was probably made for working with wood in some manner.
Black Brothers is a longtime manufacturer of wood veneer and composite laminating machinery / equipment.
cj3b_jeep
04-26-2006 05:45:06
Looks to me like part of a binder system to tie a tractor or truck to a trailer. Looks like you can take the chain off one end, put it around and axle and then put your binder on the loop and bind you load down
Slowpoke
04-26-2006 01:47:23
Looks like part of a chain style pipe vice.
Slowpoke
04-26-2006 01:58:06
 Re: Tool, what is it? in reply to Slowpoke, 04-26-2006 01:47:23
On second thought, a chain pipe vice uses a different type of chain.
davpal
04-25-2006 22:31:53
I wonder if that is a fence post puller. Maybe put the chain around the post and the hook from a seperate chain and tighten it up around the post and the hook and then pull post out of the ground with a loader?!!Just a longshot guess at best.
JMS/MN
04-25-2006 20:41:17
Is the handle attached to a threaded part, which pulls the chain tight? Used to bundle stuff together?
