Tool Talk Discussion Forum
Steel Connector Plates for Heavy Timbers
PaulW_NJ
04-23-2006 19:09:27
Does anyone know a manufacturer for flat, 1/4" thick steel plates I can use to lag bolt junctions of 6x6 or 8x8 timbers? When I jacked the floor joists on my old bank barn, I did so by laying 6x8 oak timbers, 8 or 10 feet long, under groups of them, jacking them together, and then setting the horizontal timbers on top of vertical 6x6 posts, in turn sitting on new concrete piers. (The old joists had sagged anywhere from 2 to 5 inches because both the sills and the joist ends had rotted) After sistering all of the floor joist ends, and replacing the sills, I left the timber structure inplace as extra support.
It"s been just sitting that way for several years, but now that I"ve poured a floor in the downstairs of the barn, and will be pulling tractors in there, I"d like to tie the horizontal and vertical timbers together with steel plates to provide better structure. I could buy 1/4 steel plate and burn the appropriate sized connector plates and drill the holes on a drill press, but I need 15 of them and can"t believe someone doesn"t make something like that. I"ve been putting this off and would like to finish it up. Any ideas would be appreciated.
PaulW_NJ
04-24-2006 13:36:36
 Re: Steel Connector Plates for Heavy Timbers in reply to PaulW_NJ, 04-23-2006 19:09:27
Thanks guys!
nc140man
04-24-2006 02:43:09
Simpson Strong-Tie, leading manufacturer of metal connectors. Any decent bldg supply can get them. You are looking for ps418 hangers. Dimensions are 4"x18" 5/16"thick. They are called piling straps, used on every house here on the coast of Carolina to secure bottom of house to 8X8 pilings driven into ground! Scott
2x4
04-23-2006 23:22:54
www.miller-post-beam.com/connections.html
