Tool Talk Discussion Forum
making 3 point forklift need help
sjh
04-21-2006 15:26:58
I am making a 3 point forklift from a old forklift. I do not have any 3 point lifts on my tractors to measure. Can any one give me some dimensions of the lift arms, and suggestions of were to place the pins on the lift? Thanks
Scott
Rod (NH)
04-21-2006 16:46:51
 Re: making 3 point forklift need help in reply to sjh, 04-21-2006 15:26:58
Hi Scott,
I'll link you to an old SAE spec (before ASAE took it over) that shows both the dimensions associated with tractors and the dimensions associated with implements for cat1, cat2 and cat3 agricultural three point hitches. The document is old but I don't think such dimensions change much over the years. The spec is in Adobe .pdf format that I have uploaded to a host on the net. I'll leave it posted there for a couple days so you can get a chance to get a copy. I'll then delete it to save bandwidth - I only get so much free bandwidth from the host and too much traffic will shut it down altogether. Go here for the pdf file. Make sure you use the zoom function in the Adobe reader to more clearly see any difficult areas. I hope it provides the information you are looking for.
third party image Rod
sjh
04-21-2006 19:31:33
 Re: making 3 point forklift need help in reply to Rod (NH), 04-21-2006 16:46:51
Thanks Rod. That was what I needed.
Scott
Rod (NH)
04-22-2006 05:33:04
 Re: making 3 point forklift need help in reply to sjh, 04-21-2006 19:31:33
I'm glad you got it Scott. The lurkers are killing my bandwidth though. I prefer to conserve it for other purposes so I have now deleted the file.
Rod
fred kobs
04-23-2006 00:40:52
 Re: making 3 point forklift need help in reply to Rod (NH), 04-22-2006 05:33:04
Hey Rod, I was one of the lurkers, wanted to tell you thanks for the info. Got a couple things in mind but knew I couldn't build them w/out lots of help in the geometry department. Thanks again. Fred
