Tool Talk Discussion Forum
OHV BriggsStratten help
Butch(OH)
04-21-2006 05:32:46
In-laws 16HP Crapsman mower has a vertical shaft 1 cyl B&S motor with overhead vales, I didnt write the model down. Anyway I took it down because it needs rings. I need specs for the valve lash and I noticed it has one steel push rod and one aluminum push rod. Which one goes where? Thanks.
TopCat
04-21-2006 21:45:22
 Re: OHV BriggsStratten help in reply to Butch(OH), 04-21-2006 05:32:46
The aluminum rod is for the intake valve. At the website www.briggsandstratton.com they have a page that will give you an IPL(intergrated parts list)in PDF format. The IPL has expanded parts drawings lists and some parts descriptions...I hope this helps...Good luck
