Tool Talk Discussion Forum
Wherec can I get a bolt (Puller)
ldj
04-19-2006 05:29:16
I need to remove a spark advance mechanism from an Isetta engine. It is on a tapered shaft and has internal 10mm x 1.0mm threads. To remove it you you need to screw a bolt in till it bottoms out then tighten and it will pull it off. Problem is I can't find a bolt with those threads. Any ideas where to get one.
L.D.
Mike M
04-19-2006 07:32:46
 Re: Wherec can I get a bolt (Puller) in reply to ldj, 04-19-2006 05:29:16
Sounds like you need the same kinda tool you use to pull motorcycle fylwheels ?
ldj
04-19-2006 09:02:23
 Re: Wherec can I get a bolt (Puller) in reply to Mike M, 04-19-2006 07:32:46
Mike,
You are very close. It is an Isetta which uses basically a BMW motorcycle engine. The bolt/tool it to remove the spark advance from the armature which is on the opposite end of the crank from the flywhee.
L.D.
Mike M
04-19-2006 19:22:31
 Re: Wherec can I get a bolt (Puller) in reply to ldj, 04-19-2006 09:02:23
Have you tried any local bike shops ? or DennisKirk.com ?
ldj
04-19-2006 07:29:15
Tim, I'm sorry, I needed 2 , a 10MM x 1.5mm and a 17mm x 1.00. I did find the 10x1.5 but not the 17x1.00. I made an error when I posted and didn't notice untill I read your re:. Soooo it is the 17mm x 1.00mm I need and yes it is a fine thread especially for that large.
L.D.
TimWafer
04-19-2006 06:16:14
That�s an extra fine 10mm bolt. I would think you could find it locally but if not email me and Ill send you one. I manage a True Value Hardware Store and we carry them in stock.
Tim
