Tool Talk Discussion Forum
Help! water pressure system problem
Rod in Smiths F
04-15-2006 13:47:35
The water pump which supplies my mother's house was cycling on at short intervals. It seems to be a bladder tank, so I fumbled around until learning how to add air to the bladder. That done, the pump still comes about every ten minutes and runs for one minute or so.
The static level in the well is only about 36' and the foot valve is down in the well, capped by a cast iron hand pump installed with a foot valve in the same hole, so I'd like to avoid pulling the whole mess, if I can help it.
Is there any other cause but leaking foot valve clamps if I have eliminated other leak sources?
I should have asked you guys sooner; Wilkipedia is not much help on this topic.
Thanks,
Rod
Rod in Smiths Falls, ON,
04-17-2006 14:31:34
 And the problem turned out to be.... in reply to Rod in Smiths Falls, ON, , 04-15-2006 13:47:35
A leaking toilet. A wooden spoon under the float and the pump stayed silent for hours. Now all I have to do is replace the guts of the flushing mechanism.
While a bit embarrassing, it's a lot less effort than pulling the foot valve.
I know, "Water runs downhill and payday's on Friday," but a lot of plumbing is trickier than it looks.
coloken
04-15-2006 17:43:14
 Re: Help! water pressure system problem in reply to Rod in Smiths Falls, ON, , 04-15-2006 13:47:35
Read Joe(Wa) again
Chas Schondorf
04-15-2006 16:04:23
More than likely the foot valve is leaking.
You have to set the pressure a few pounds below the ON pressure of the water pump with no pressure on the bladder.
04-16-2006 05:38:44
 Re: Help! water pressure system problem in reply to Chas Schondorf, 04-15-2006 16:04:23
Oops! I set it at 38 pounds in the bladder, and the on pressure is thirty. I'll check that this morning.
Joe in MN
04-15-2006 14:21:14
Could be --- the bladder in your tank has a leak, and will not perform like it should, if the tank is more then 5 years old, most likely the Bladder is no good... replace it with a new tank with bladder, and it will give you another 5 years of service...
Joe (Wa)
04-15-2006 14:17:17
If the pump is submersed, I would put a check valve in the pump piping near the tank and forget the foot valve.
Joe
04-16-2006 05:43:24
 Re: Help! water pressure system problem in reply to Joe (Wa), 04-15-2006 14:17:17
That's an interesting idea and would eliminate a lot of lifting, though I only have about 18" of vinyl (two lines) coming through the stone wall, so it would have to be down the well where there is room. I'd need two check valves, though.
It's a jet pump with the lower half down the well and the foot valve attached, a deep well application.
Gus Hansen
04-15-2006 14:13:12
Hi. Did you drain the water out of the tank before you added the air. when there isn't any air in the tank keeps filling with water, so when you put the air back in the tank there is no place for the water to go. Shut off the water to the tank and open the value to let the water out, then put air to the tank to get extra water out of it. Then shut off all the values and put the air in the tank. Should work then. Hope this works for you.
04-15-2006 14:19:55
 Re: Help! water pressure system problem in reply to Gus Hansen, 04-15-2006 14:13:12
Gus:
That's exactly what I learned how to do, after much fumbling. It still is losing pressure. What's the next step?
Rod
Fern(Mi)
04-15-2006 14:46:51
 Re: Help! water pressure system problem in reply to Rod in Smiths Falls, ON, , 04-15-2006 14:19:55
The draw pipr may have a hole in it, causing the loss of presure back down into the well. Had to replace an original 1 1/4" draw pipe with new cvpc(?) pipe about a yr ago. also replaced pump at same time it also getting old.
my thoughts only.
Fernan
oldart
04-18-2006 18:59:50
 Re: Help! water pressure system problem in reply to Fern(Mi), 04-15-2006 14:46:51
if you have to pull the pipe out consiser changeing fro a jet pump to a submersibale pump i feel they ar more reliable.
