Tool Talk Discussion Forum
b/s push mower
wfw
04-15-2006 10:31:56
have a push mower with briggs engine. every time you start it you have to push the primer bulb five or six times. doesn't matter if its cold or has been running for an hour or more. Any suggestions on what is causing this? runs good otherwise so if expensive then i will just leave it like it is. thanks for any suggestions
souNdguy
04-15-2006 22:00:34
 Re: b/s push mower in reply to wfw, 04-15-2006 10:31:56
My 12yold bs push mower is like that. Done it since day 1... Book says 3 pumps.. with only 3 pumps.. you get a ired arm trying to start it.. 5 pumps is better..
Soundguy
steve from mo - dangit!
04-15-2006 10:45:45
 Newer model? in reply to wfw, 04-15-2006 10:31:56
The newer ones have a fixed-speed carburetor that makes them run pretty lean. There's no other provision for enriching the mixture for starting, so you keep on pumping until it goes.
If it's an older model, you may have something plugged up.
