Tool Talk Discussion Forum
Milwaukee rotary hammer
Mike from cny
04-14-2006 21:52:35
Just picked up a Milwaukee rotary hammer tonight, model 5347. Claims to have 1 1/2 stroke. Looks to be a older model, came with the case and a chisel bit. Problem is, it doesnt have very much stroke when running, maybe a 1/2 inch. However the motor half works fine and was hoping it would be fixable.Is this worth fixing? Just wondering if anyone is familier with these things. Thanks.
RegoR
04-17-2006 06:36:42
 Re: Milwaukee rotary hammer in reply to Mike from cny, 04-14-2006 21:52:35
Hi Mike;
I have an older Milwaukee rotohammer (model?) and the 1-1/2" refers to the max size core bit it can handle.
Roger
van robinson
04-16-2006 19:54:19
may need to change brushes.
Steve Crum
04-15-2006 04:46:17
You'll like it, and it will likely out live you.
Big problem is remembering who borrowed it last.
Chris(WA)
04-15-2006 04:05:38
What the 1 1/2"usually means is the largest size bit it will handle is that size. The stroke probably is about 1/2".
tn terry t
04-15-2006 04:31:46
 Re: Milwaukee rotary hammer in reply to Chris(WA), 04-15-2006 04:05:38
i ues a hammer drill almost everyday in my job you couldnt hold on to it if it moved an 1.5 inch everytime it hit
