Tool Talk Discussion Forum
Chainsaw problem
Jim- DR
04-13-2006 18:00:00
Last year my Stihl chainsaw wouldn"t start and I found the sparkplug to be loose. The threads were stripped and the plug could not be put back in, so I took it to the dealer who put in a Helicoil. The saw worked great for several months, but yesterday it wouldn"t start. I took out the plug to see if it was flooded and the helicoil came out with it. I thought the dealer was going to epoxy the helicoil in. Am I wasteing my time trying another helicoil, or should I consider a new saw?
Charles (in GA)
04-14-2006 16:15:45
 Re: Chainsaw problem in reply to Jim- DR, 04-13-2006 18:00:00
Get a new heilcoil put in, make sure that the end of the coil is just below the surface so it can dig in and help keep it from coming out.
As also mentioned, use antiseeze on the threads of the plug and it will come out easily without bringing the coil with it. DO NOT get any antiseeze on the electrodes of the plug or it will short out and not run.
Otherwise replace the head.
Charles
jeffcat
04-14-2006 09:51:19
My two cents on this one. Use anti-sieze but you want the gold color stuff. jeffcat
Yugrotcart
04-14-2006 05:28:25
Find a junker saw, take the head from it, put it on yours. I have a friend that owns a rental business, he has lots of used parts..... ...
2x4
04-13-2006 21:52:20
when the plug is left loose, escaping gases erode the treads & finally the plug comes out. We epoxyed one in once & it blew out while using it. Its a lost cause but on your saw a new or used cylinder is real quick & simple to install. Takes about half hour.
Paul from MI
04-13-2006 18:45:46
Don't know if there's room, but you might re-tap your head for the next larger diameter plug. Then you'll have to cross refereence to get the right reach & heat range. Other wise you'll probably have to replace the head. Anti-sieze on the plug will help eliminate a repeat problem. I don't think replacing the saw is needed, but if it is, you can e-mail me and I'll give my address-ship it to me(just kidding of course).
Good Luck,
Paul
