Tool Talk Discussion Forum
Wheel bearing pullers
MN Bob
04-12-2006 16:58:35
Checked at the equipment shop, they want $50 to $70 per wheel to pull, pack and new seals. I have 16 on road trailers. 12 on field (hay wagons), who knows on implements and mowers, balers etc. So what is a good tool to have on the farm to do my own?? All ideas and help appreciated. Bob
Dan Hill
04-15-2006 02:30:51
 Re: Wheel bearing pullers in reply to MN Bob, 04-12-2006 16:58:35
New seals are 3 or 4 dollars.Boat trailer bearings should be watched closely but other equipment doesnt need this much attention.I look at bearings for pits and corrosion.Turn the bearing in its race to feel for roughness.There is usually plenty of grease in the hubs.If the seal is ok the bearings should be fine.I have a cone type bearing packer that uses a grease gun.You have to keep and extra grease gun with wheel bearing grease in it and tag it for wheel bearing grease only.I often put some grease in a plastic bag and pack the bearings by hand.All new bearings seem to be imports now.I would rather have old US made bearings in my equipment.Any seal that shows grease leakage will let water in and should be replaced.50.00 per wheel is robbery.I was looking over a price sheet from a sharpening shop.I machine sharpen and set 30 inch cord wood saws for 10.00 to 20.00.They charge 60.00 for the same job.Learn to do the job your self and keep your cash in your pocket.
Eddie in MI
04-12-2006 19:54:32
Okay, I am not necessarily saying taht this is a "good" tool, but here is a bearing puller from Harbor Freight.
Link
I am sure that a company like OTC has to make an American-made version...
MN Bob
04-12-2006 18:12:43
Thanks guys; Yes, I have used the hammer for many years. Was sort of hoping that there was a better removal tool. The insertion tools shown would be handy. I have always taken a old race and ground it off just a little and then used it to seat the new one. Again, many thanks. Bob
JMS/MN
04-12-2006 17:42:40
Hammer and chisel to pop the bearing cap, pliers and flat screwdriver to get the cotter key out, adjustable wrench to unscrew the nut, drift pin to push out the inner bearing and seal, or races if necessary. Maybe 15 minutes per wheel?
Charles (in GA)
04-12-2006 17:42:07
third party image
A bearing packer, here is the best one I've found, available from several sources.
Link
Link
A bearing race/seal driver tool set.
Link
Charles
Charles (in GA)
04-12-2006 17:43:18
 Re: Wheel bearing pullers in reply to Charles (in GA), 04-12-2006 17:42:07
third party image
Wanted to show the bearing race drivers also.
Charles (in GA)
04-12-2006 17:46:19
 Re: Wheel bearing pullers in reply to Charles (in GA), 04-12-2006 17:43:18
third party image
A parts washer comes in handy also to get those bearings clean.
I can only suggest the best (ha, ha) a Graymills unit would be real nice. See pic.
Charles
