Tool Talk Discussion Forum
Who here has a corn stove?
Midwest redneck
04-12-2006 15:26:50
What does corn cost, in your area? I called a local place (5 miles from me) they will sell me bagged corn at $8/100 pounds. Does the price move around much from year to year? I figure that corn is half the cost of propane. It will cost me $800/winter to heat with corn and $1,600-1,800 to heat with propane. What kind of corn stove do you have? how much did it cost? What does it really cost to run it in the winter? What area of the country do you live in? I called a corn stove dealer in my area and it is $3000 for the Harman corn stove.
Arlen- MN.
04-12-2006 19:33:25
 Re: Who here has a corn stove? in reply to Midwest redneck, 04-12-2006 15:26:50
I put in a St Croix corn stove in the last day of October. Cost 2600.00 Installed.Burned about 1 bu. of 15% corn per day. 1.80 to 2.00 a bu. This was along with an oil furnace in an old uninsulated farmhouse in SE Mn. This worked very well, but of course we did have a mild winter. I figure I used about half or less the furnace oil I would have used. The stove worked well with out any problems.
Bill in Ohio
04-12-2006 19:10:46
We have 3 of them, and, in general, we like them. Some stoves are a bit temperamental, and it seems there can be fairly big differences in corn from one batch to another. The last stove we got is a Countryside, and it has adjustments on the air which is supposed to let you burn corn, wood pellets or biomass pellets. The downside of this is its hard to set the air just right, and if it aint right, it soots up real bad, real quick. You probably don't want to buy your corn from a feed mill for 2 main reasons, it will very likely be contaminated with molasses from their feed mixing and bagging operation, and mainly, they charge about double for the stuff. Its got to be clean! The grindings are what stops a stove in short notice, it burns so fast that it doesnt get down into the burnpot before it turns into a giant black popcorn ball. The corn should be dry. My buddy dried some down to 11% for me, like my owners manual called for. I wonder who wrote that thing, it didnt seem to like it that dry, made lots more soot. This stove has an agitator in the firepot which gets a lot of clinker buildup on it. The owners manual calls for a clean burn additive to solve that problem, but it was NOT available, SO, we used chicken grit, mixed in with the corn to more or less solve the problem. OF COURSE THIS VOIDED THE WARRANTY! We had a Snowflame, wouldnt recommend it at all. The burn air is pressurized into the stove and when it gets sooted up the smoke will back up into the grain tank and the resulting water and acid eats it up! The acid eats it up so fast, that in a day or so a "sheet" of rust falls off the inside of the tank. I have never seen anything rust that way, and furthermore, I havent found anything that would prevent that rust, either! So, I have a junk stove in 3 years. We have an Amaizeing Heat furnace, 100,000 BTUs, and it is the most dependable of all. It does require a couple minutes of clinker removal, preferrably twice a day, but, the heat is almost like any other furnace, on demand. To maintain a fire it has a timer that automatically feeds a little in every 8 minutes or so. Our timer is not working and it did go out a couple of times this winter because of that. If I were buying another stove, I would sure investigate the Harmon and Bixby stoves. Go to a reputable dealer like Rural Energy in Van Wert,Oh, or Bob Snively in McComb, Oh. You will be glad you did.
We used about 500 bushels of $2 corn to heat 2 homes this winter in southern Ohio. We probably used almost 20 cords of junk wood to get that much heat when we used wood, so, I feel the stoves are a decent investment.
ldj
04-12-2006 17:16:43
There are several forums in Yahoo groups. Just look up cornstove in their groups. You can spend some time reading back through old posts and learn a lot. Maybe even get more confused? I've had a pellet stove for about 15 yr. and been burning 2/3 corn 1/3 pellet mix for several years. I'm planning on getting a new corn burner before next winter. I live in Cen. Tx. so winters not bad.
L.D.
MN Bob
04-12-2006 16:54:44
I havent bought one yet. A friend has a delaership in them. You need S/Steel exhaust. I figure close to 3000. to install one for my home. Corn is how you buy it. If you can find a farmer that drys down below 15% (preferably 12) and buy in bulk that is how you will save heat $ and get you pay-back on the stove cost. So you will need to store up to 200 bushels of corn. You can make a cleaner pretty easy. Most end up adding some pellets to make a cleaner burn. There are other clean-burn additives. Its as close to wood heat without the mess as you will get but you may not find the pay-back for a few years. Just what I have found in looking into it. Good luck..
Kevin Bismark
04-12-2006 19:08:41
 Re: Who here has a corn stove? in reply to MN Bob, 04-12-2006 16:54:44
I tried the baby countryside stove, piece of junk, will look for another corn stove for next winter, this model is designed not to work, but my folks and brother have another model that is better, so I might look at it, have my eye on a couple that are a lot better, hope to move where I can park a gravity box next to the garage and make one trip for corn. So far I would have to say the "clean burn" stuff is a scam never made any difference for me, a small scoop of wood pellets worked better and was cheeper, had a friend who had dried down a bin of corn to 11% so I went and bagged my own and hauled it home but is a lot of work, but burned really good.
Kevin
redrunsdeep
04-18-2006 23:46:51
 Re: Who here has a corn stove? in reply to Kevin Bismark, 04-12-2006 19:08:41
I have one and love it my corn bill is about $60 a month during the colder times.
I got all the advice on my stove from Jason at a company called J&W Corn Fuel Systems they sell storage transfer and cleaning products for corn and pellets he know all the pros and cons about all the brands of stoves and furances he doenst deal them but recommended a dealer to me and save me about $400.00 on the stove I bought.
Give him a call I am sure he would be happy to answer any questions you have he is a great guy to deal with. He sure saved me a ton of hassel when I was trying to choose a corn burner.
