Tool Talk Discussion Forum
OT: Fuel pump, '93 Jeep Cherokee
Slowpoke
04-12-2006 10:25:55
Any body know an easier way to replace the in-tank fuel pump besides removing the gas and dropping the tank? There's a lot of trim holding the carpet down.
Is there an access under the carpet that's not mentioned in the manual?
Thanks,
Slowpoke
rileyspop
04-12-2006 21:37:38
 Re: OT: Fuel pump, '93 Jeep Cherokee in reply to Slowpoke, 04-12-2006 10:25:55
There will be a mesh "sock" on the bottom of pump it is a pre filter to protect pump rotor from chunks. Most of the time the are able to be reused after a slight flush in clean solvent or fuel.
CNKS
04-12-2006 17:03:29
No -- the service manual says you have to remove the tank.
Slowpoke
04-12-2006 21:37:49
 Re: OT: Fuel pump, '93 Jeep Cherokee in reply to CNKS, 04-12-2006 17:03:29
Yes,I know, but I was hoping...
RandyBee
04-12-2006 15:19:22
I don't know of a ispection plate in the floor but it is no big deal to drop the tank and replace the pump. You don't have to drain the tank dry, just be careful with open fuel around.
cheifrunamuk
04-12-2006 13:27:01
Slopoke; could you not put an external
fuel pump on this, maybe could not suck
fuel thru internal fuel pump? ken
Maark
04-12-2006 10:49:05
I replaced one in my brother-in-laws jeep a couple of years ago, it came out the back of the tank. Didn't need to drop. It might have been a couple years older though.
Slowpoke
04-12-2006 14:43:18
 Re: OT: Fuel pump, '93 Jeep Cherokee in reply to Maark, 04-12-2006 10:49:05
I replaced a pump on a '95 Neon a couple of years ago. Access was from the side and not too difficult. The Cherokee is on the top. Both are Chrysler products as is your Jeep. Why can't the engineers all use the side or back location instead of a dumb place like the top? It's probably a $400-500 shop bill.
Bryan in Iowa
04-12-2006 10:42:14
Drop the tank,,,not that hard to do ,,make sure you put new fuel filter on too.
Slowpoke
04-12-2006 10:52:43
 Re: OT: Fuel pump, '93 Jeep Cherokee in reply to Bryan in Iowa , 04-12-2006 10:42:14
Filter is external to tank. Of course there could be some sort of filter on the pump itself.
