Tool Talk Discussion Forum
Type of pump
R Spence
04-08-2006 05:18:37
I want to purchase a 3 point sprayer for my Ford 860.
What type of pump should I be looking at, the 12 volt electric style or the pto style?
JMS/MN
04-08-2006 09:13:48
 Re: Type of pump in reply to R Spence, 04-08-2006 05:18:37
Another point about roller pumps vs. centrifugal, is the roller material needs to be compatible with the herbicide you are using. Nylon, viton, steel? Don't know about current pumps, but years ago it was an issue.
Coloken
04-08-2006 07:04:01
Like RJ says, The roller pumps are common. What size sprayer are you making? If a small one with just several nozzels, then the 12 volt ones would be the easiest. But they pump something like a couple of gallon per min. If you need a larger volume then the PTO ones. If very large volume, look at the pto centrifical ones, they have the biggest volume.
R Spence
04-08-2006 07:47:58
 Re: Type of pump in reply to Coloken, 04-08-2006 07:04:01
I just want to do about 5 acres of food plots...maybee a 12 foot boom?
RJ-AZ
04-08-2006 06:41:34
I always liked the Hypro roller pumps hooked to a regulator with a bypass for agitation. It's east to set up for booms, broad jet or hand wand. It can be used as a pressure washer as well for machinery cleanup.
