Tool Talk Discussion Forum
oil fill
Mattchew
04-05-2006 11:52:02
I am VERY new to the tractor field and I am gettig ready to change the oil in my grandfathers WD45. Where is the oil fill located, is it the cap that looks like a breather underneath the hood?
JMS/MN
04-05-2006 22:12:06
 Re: oil fill in reply to Mattchew, 04-05-2006 11:52:02
Old told you where the oil fill cap is- the one just forward of the distributor. You are right about the breather under the hood- it is a breather cap..... not an oil fill. Best to get an OPERATOR manual- tells you about all the lube requirements and controls, fill and drain plugs for the several systems as well as rear end, final drives, etc- all according to ambient temps that you run the tractor in- that is also important. Also details about setting the hydraulic system for what you want it to do. Best fifteen bucks you can spend.
old
04-05-2006 15:47:10
Its on the right side of the engine between the distutor and the radiator.
Mattchew
04-05-2006 21:17:16
 Re: oil fill in reply to old, 04-05-2006 15:47:10
I thought that was for the power sterring fluid, shows how much I know.
Mattchew
04-06-2006 12:37:24
 Re: oil fill in reply to Mattchew, 04-05-2006 21:17:16
I appreciate all the help and yes I did see the power sterring/pump underneath of the hood. The guy with the oil in the exhaust pipe doesn't make me feel so stupid now.
JMS/MN
04-05-2006 22:15:56
Factory power steering was an option not offered before 1956- does your tractor have it? Should be a small tank mounted under the hood- that is the oil reservoir- if it is factory.
old
04-05-2006 21:26:10
Well if you look at where the distibutor is mounted just forward of it and on the same casting area is where you add/fill the engine oil. Theres also one under the hood but you have to remove the hood to be able to use that place.
dan hill
04-06-2006 03:45:33
 Re: oil fill in reply to old, 04-05-2006 21:26:10
I worked for a fellow who put 2 quarts of oil down the exhaust pipe of a Farmall M.It didnt have a muffler on it.He made a million hatching chicks but was dangerous around machinery.
