Tool Talk Discussion Forum
Slow Speed Water Cooled Sharpners
DH in Carolina
04-04-2006 14:11:40
Are these slow speed water cooled sharpners any good for sharpening wood chisels or cutter blades? I was looking at Delta brand. Know they are probably made in China. What do you think? Thanks in advance DH
hayray
04-06-2006 03:43:01
 Re: Slow Speed Water Cooled Sharpners in reply to DH in Carolina, 04-04-2006 14:11:40
A good powerful belt sander works much better and is more versatille.
MikeCatthemuseum
04-06-2006 21:34:54
 Re: Slow Speed Water Cooled Sharpners in reply to hayray, 04-06-2006 03:43:01
maybe for grinding axes.
MikeCatthemuseum
04-04-2006 23:20:01
I have one of these. The el cheapo ones have one major design flaw... the water goes everywhere and there is no catch basin. It makes a mess so set up outdoors or use a dishrack drain tray beside the sink.
As for the edge, it depends on how good you are at sharpening. My 8" kitchen knife is like a scalpel. Pocket knife is likewise. It'll also do wonders on an abused wood chisel. Rough it out on a bench grinder taking care not to burn it up and then polish up on the wet wheel.
For best results, rough with fine bench grinding wheel, polish with wet wheel, hone with arkansas stone, then razor hone if you have one, and finish with leather strop. Then be careful and try not to cut your arm off.
upred
04-04-2006 20:12:38
check the tormek brand - available at Woodworkers Supply, nice unit
charlien
04-04-2006 18:58:13
I got a craftsman that will put an edge on you can shave with.
Bernoulli
04-04-2006 18:56:28
I had a Delta that I used sucessfully to sharpen wood chisels. Worked fine. Didn't sharpen any cutter blades.
Gene Davis (Ga.)
04-04-2006 18:26:18
I have an older model made by Wen, and it does a beautiful job of sharpening tools. The flowing water bath keeps it from burning blue spots on the blades.
Gene Davis (Ga.)
04-04-2006 18:26:04
