Tool Talk Discussion Forum
Replacement Cords
Dave Sherburne
04-04-2006 10:22:13
I have two reelamatic droplights that need new
cords What type of wire should I look for?
Slowpoke
04-07-2006 00:15:24
 Re: Replacement Cords in reply to Dave Sherburne NY, 04-04-2006 10:22:13
As already said, check the cord for identification. It's there 99% of the time, all along the cover. You might need to use a magnifying glass if it's quite worn. Cleaning and bright light will also help. Use the same size and type for replacement as a larger size won't fit the mechanical part of the case. And it will be the right flexibility.
Farmall_Ryan
04-05-2006 14:44:05
The ground wire isn't counted as a conductor when labeling the cable/cord.
14/2 would have a white and a black as the conductors, plus a ground.
14/3 would have white, black, and red plus a ground.
Ken Crisman
04-04-2006 13:38:59
14-2 with grd SO or SJ cord
LumbrJakMan
04-04-2006 13:27:11
If NO receptacle for power on the drop light 16/3 SJO Cord . If it has a place to plug in 14/3 SJO cord .
16/3 = 16 AWG wire, and 3 conductors, Black white and green
14/3 + 14 AWG wire and 3 conductors, Black white and green
Black = HOT, White = Neutral, Green is GROUND .
HOT is the Screw that connects to base of Light bulb
Neutral comnnects to Screw Shell of Light bulb.
Green is ground .
jeffcat
04-04-2006 11:40:23
If you look vrey carefully along the side of the cord you might find the old numbers. If not, cut off a little piece and take it with you to the store. Most lkely 14 but this is a way to check. Jeffcat
david e stephenson
04-04-2006 10:44:19
i would use 14/3 cord because 12/3cord would be to heavy to pull around all the time
