Tool Talk Discussion Forum
BriggsStratt WM gas intake problem
DCM
04-03-2006 20:54:58
The brass intake in the gas tank seems to get stuck.If I remove it and poke it loose it works,shut it off and its stuck again,is it carmelized due to old gas and is there way to free that little valve up.Could I soak it it paint thinner? Dan in AB
Wayne Swenson
04-03-2006 21:09:42
 Re: BriggsStratt WM gas intake problem in reply to DCM, 04-03-2006 20:54:58
Use lacquer thinner or carb cleaner or paint thinner. The brass parts are not going to get hurt from the chemical.
I have a WM also; haven"t used it for a few years. When I shut it off, I would drain the gas tank to prevent fuel problems the next time.
dan hill
04-06-2006 03:59:01
 Re: BriggsStratt WM gas intake problem in reply to Wayne Swenson, 04-03-2006 21:09:42
The valve will hold enough gas to stick the ball even with tank drained.Try starting it after the tank has been drained to get rid of the gas in the valve.This is a common problem with these engines and later Briggs lawn mower engines.
DCM
04-03-2006 21:21:39
Thanks Wayne,I will soak it,just got a decal from for it,have painted it and want to display it.Dan in Alberta
