Tool Talk Discussion Forum
air compressor help
rileyspop
04-03-2006 16:17:32
I have aquired an air compressor with a burnt-up motor. It is a large unit with a two stage pump, I believe it had too small of a motor and pulleys changed so it would run. It only had 1.5 hp motor, and recovered slow but made good pressure. I got it from a freind who used it for 4 years. It was completely rebuilt(the pump) just after he got it. It was painted red, but was originally metalic blue. The tool repair shop that rebuilt it cleaned the paint off the i.d. tags along with the mfg.name. I need the rpm/hp this thing was supposed to run at to get new motor/pulley. Mfg was not listed on reciept from overhaul, and shop went belly up. Unit has cooling manifold between stages, sits completly upright,a tool repair man i talked to thought 40 year old speedaire, has WA4043R casting # on crankcase tag has two #'s stamped in 703 and 3-36-wu. Stand frame has vt-715-60 any clues!! Sorry no pics yet
Charles (in GA)
04-05-2006 19:14:16
 Re: air compressor help in reply to rileyspop, 04-03-2006 16:17:32
I was hoping Rodger would see this, he is the aircompressor guru, and may be able to help.
Charles
rileyspop
04-04-2006 23:47:21
Please help, any Ideas would be apprectiated, I have spent hours on the web with no leads and have exausted all local sources. Thanks
