Tool Talk Discussion Forum
Changing blades in Delta bench jointer..
Dick2
04-03-2006 14:59:40
Recently saw a post that a guy could not get the cap screws loose to change blades in his Delta bench jointer. He was talking of throwing the whole thing in the trash. I went to change blades today for the first time in my Delta jointer and couldn't break two of the cap screws loose; they just rounded out the hex wrench in the screw.
Used a 1/4" drill and drilled just deep enough, then got under the edge of the head with a small chisel and popped off the heads. Removed the back-up bar and blade and turned the screws out by hand. Picked up new 1/4 - 20 X 5/8 cap screws at the True Value, put on some anti-seize lubricant and put in the new blades. I'm back in business.
