Tool Talk Discussion Forum
Torque multiplier
Slowpoke
04-03-2006 11:30:24
I interested in buying a used 3 to 1, 1000lb Sweeney torque multiplier on ebay. Item #7605874599. It doesn't have a handle, so is it used with a torque wrench? If the multiplier is 3 to 1, and the wrench is set to 100lbs will the torque be 300lbs? Or does it release at 1000lbs using a handle of some sort? On one side of the head is a 3/4 drive for a socket. What are the two "walls" for next to it? Are they for the handle? The seller has two others listed, also.
Thanks in advance for your answers.
Slowpoke
M.R.
04-04-2006 08:33:13
 Re: Torque multiplier in reply to Slowpoke, 04-03-2006 11:30:24
Hi Jerry
Just do and advanced search in 'All Categories' using 'Torque Multiplier'. 'Torque wrench'
KIP in MX
04-03-2006 18:57:30
We use some multipliers for helicopter mast bearings and main rotor heads. Some don�t have anti-torque handles, they mount onto component being torqued. That 8103 model looks to be this type, but there may be a way to mount a handle on it.
Slowpoke
04-03-2006 23:49:27
 Re: Torque multiplier in reply to KIP in MX, 04-03-2006 18:57:30
Thanks for the info. Maybe that's the reason for the two semi-round walls on the socket side, to fit over some fixed part. There seems to be a protrusion on the end but it looks rather small to use a substantial handle.
Can't even use my name
04-03-2006 14:35:11
We borrowed a 4:1 several years ago to tighten a yoke on a semi rearend, needed to be at 1000 ft/lbs. There was the 3/4" male socket side, a handle to hold it still and then a 3/4" female receptor on the front for a ratchet, breaker bar, or torque wrench. So somewhere there is a hole to put a handle of some sort on that thing. Kinda expensive devils if I recall. I have several large trucks now so I went and got a 1" impact capable of 1400 ft/lbs! Man is that thing awesome! Easier to use than that multiplier too.
Jerry L /AZ
04-03-2006 11:42:09
a torque multiplyer 3:1 100 lbs on torque wrench gives you 300 lbs at the socket the handle is to keep the multiplyer from rotating you can use a bar or pipe as a handle. where at on ebay did you find them ? Id like to look see. Jer
Slowpoke
04-03-2006 12:00:10
 Re: Torque multiplier in reply to Jerry L /AZ, 04-03-2006 11:42:09
Thanks Jerry, the number is in the original post above. Here it is: 7605874599. Check the other two he has. What's it worth for someone who may never need it???? I just thought it might come in handy some day.
Slowpoke
Jerry L /AZ
04-03-2006 11:40:43
a torque multiplyer 3:1 ioo lbs on torque wrench gives you 300 lbs at the socket the ahndle is to keep the multi[lyer from rotating you can use a bar or pipe as a handle. where at on ebay did you find them ? Id like to look see. Jer
