Tool Talk Discussion Forum
Sparkplug gaskets
jack12345
03-30-2006 20:33:37
I know it doesn't make much difference as the plug gaskets seem to work fine either way, but there must be a top (next to plug) and bottom (next to head).When a new plug is purchased sometimes it comes in box with gasket loose leaving it to you to install the gasket, what is the correct way? Short side up or down?
Joe (Wa)
03-31-2006 07:36:15
 Re: Sparkplug gaskets in reply to jack12345, 03-30-2006 20:33:37
Look at the seal, you will see that one ring is larger than the other. The mating surface on the plug matches the larger side of the seal. Try a seal each way and check the seating, you'll see the difference.
Joe
Mike M
03-31-2006 04:56:29
I have noticed on the ones I have that the gasket has little projections inside of one edge to hold it on the threads. I place these so they end up on the engine side of the plug because it seems if I put them on the other way the curve at the shoulder of the plug smashes them and then when I pull the plug out again the gasket just falls off.
