Tool Talk Discussion Forum
Stihl fuel lines
oldrustycars
03-29-2006 18:41:36
fixing a couple older Stihl machines, a hedge clipper, string trimmer, and a backpack blower. they are older, and have been used very little. all three have very squishy fuel lines. i recall in the 90's when they first started using 10 percent ethanol in the gas that this would happen. have the found a better fuel line now? im going to rebuild the carbs and clean the tanks also. but i feel the lines are the main trouble, you can pinch them and they stay squeezed together, causing them to have to feather the throttle, and run on partial choke. thanks.
oldrustycars
03-30-2006 08:10:44
 Re: Stihl fuel lines in reply to oldrustycars, 03-29-2006 18:41:36
thanks everyone. ethanol is the law here in all grades of fuel.
JT
03-30-2006 08:28:52
 Re: Stihl fuel lines in reply to oldrustycars, 03-30-2006 08:10:44
Don't know about your neck of the woods, but if you have a Casey's general store any where close, around here they sell one grade that is not ethenal. We buy our fuel from a bulk fuel supplier and his fuel in free of alchohal. What makes this whole thing bad is they are supposed to be 10%, and most equipment can deal with 10%, a lot of times it is 15-20%. alcohol is cheaper to buy than gas, that is why they try to sneak higher % in your gas.
lucasss
03-30-2006 07:56:38
yes,that yellow tygon gas line is great,trouble is,most stihl equipment will only take stihl oem fuel lines because of the way they are made to fit and seal in the tank...
JT
03-30-2006 06:15:53
I really think it is poor quality fuel line. The ethenal does not exibit these problems, it is usually the oposite. the alchohal will take all the oil out of the fuel lines, cause them to get hard, brittle and then crumble, normally they will not get mushy.
We still have to replace the fule lines on STihle products with the preformed lines, they are an accorian type line and they routinely crack. They claim they have made improvements, but I have yet to see it. We still have customers that use these every day and we still replace fuel lines every year on them.
Now, ethenal will cause a 2 cycle engine to be destroyed from insuffficient lubrication. The reason, alchohal is a solvent and will wash the oil off the cylinder of your 2 cycle engine and then you do not have lubrication to run an engine. It also burns hotter, so that creates cooling problems. It also destroys all the little rubber parts in carbs and dries it out making the carb parts useable, diaphrams are as hard as a counter top.
On a lot of the Stihl products, you cannot use Tygon line, they have a grommet built on the fuel line that seals the fuel line in the tank and also might seal the air box that the carb is in. The bad part, Stihl fuel lines are not cheap priced, just cheap made.
Aaron Ford
03-30-2006 04:55:33
Stihl's usually have a preformed rubber hose. Difficult to impossible to use anything else.
My local small engine shop owner can smell 87 octane a mile away. He charges for a tank flush if he suspects it. He says nothing but premium due to the hoses and seals in small engines. I think it's a little over the top, but he's extremely reasonable with his parts and labor, so I go along.
Caz(Ky)
03-30-2006 03:16:45
Stihl reformulated their fuel line material 3 years ago. Before that 3 months was a long time, I replaced all mine then and they are still going strong. John
jdemaris
03-29-2006 19:30:18
I wouldn't blame it on the ethanol. We sold Stihls back in the late 60s (S10s and 040s), and the OEM fuel lines did the same thing then - and there wasn't any ethanol around. The new Stihl saws we were selling into the early 90s still had the problem. I'd blame it on crappy German rubber.
Russ from MN
03-29-2006 19:04:00
I really try to avoid gasohol in my 2-cycle engined, in MN we can buy premium without alcohol, I think!
jeffcat
03-29-2006 18:46:32
Go to your local mower parts dealer. Take a carb with you for the size of tube. Get the yellow plastic tube. It will stand up to almost anything you can throw at it. Not cheep but it does work!. Jeffcat
oldrustycars
03-29-2006 18:51:59
 Re: Stihl fuel lines in reply to jeffcat, 03-29-2006 18:46:32
is it the Tygon fuel line they always have on spools? its usually sorta clear.
thejdman01
03-30-2006 04:05:44
 Re: Stihl fuel lines in reply to oldrustycars, 03-29-2006 18:51:59
The yellow stuff in small engine shops etc is tygon hhose, will stand up to ethanol and alcohol but wont stand up to sunlight very well.
Vern_MI
03-30-2006 03:55:34
No it is the yellow stuff they sell at small engine repair shops.
