George is absolutely right. Stick welding cast iron with nickel is asking for trouble. I have repaired dozens of such quick fixes. Many of them failed as they watched the part cool. The problem is not lack of temperature control exactly, it is the formation of white iron at the welded joint. Iron cooled very fast (as in dabbing a little at a time with an arc rod) becomes chilled and forms white iron... just like they used to do with old heavy lathe beds to make them so hard you can't cut them with a file. White iron is brittle and has NO tensile strength, thus, it cracks and tears out when put under stress. That's why arc welding iron is SO bad. I had to drill and tap four holes in my lathe to repair a crack that had been dabbed at with a nickel rod. It drilled like soapstone until the weld zone, I then went through THREE dril bits on EACH hole to penetrate the white iron. It was like drilling carbide. Unless you have a severely well equipped shop with an oven to preheat and slow cool your part, I strongly suggest brazing with an OA torch. That is the best fix for the average guy. I discovered a technique in an old 1940 Oxyacetylene Handbook that mentioned reinforcing the braze to improve performance. I took this and improved on it even further. If I have to repair a broken machine member, I first try to mill out pockets and install steel bar keys or plates to hold the parts in alignment and go so far as to drill and tap bolts or screws to hold these keys in place and hold the break solid. I try to make this reinforcement strong enough to function as a serviceable repair by itself. I then take the whole works apart, V-notch the break, and put it all back together tightly. I preheat, sprinkle liberally with granulated flux, and then braze the break, braze over the keys with them bolted firmly in place, and even braze over the bolts to lock them in place. I let it air cool at room temp. I finally grind and file the repair flush. The repair is invisible under paint and not very obvious even on bare metal. The end result is the same as steel-reinforced conctrete. The keys take the stress and the braze keeps anything from ever moving. This repair practically eliminates the possibility of white iron formation and is stronger than the original part. My repairs have been 100% successful. Very few can claim that success rate on cast iron repairs.
