Prepping aluminum for painting
ANY SUGGESTIONS ???
Alberta Mike
03-01-2001 16:59:44
I have made some panels out of sheet aluminum for one of my tractors. Is there anything different or special about prepping or preparing aluminum before painting? Also, is there any special primer that is used? I am just using ordinary machinery enamel for the finished product.
Al English
03-01-2001 18:21:29
 Re: Prepping aluminum for painting - ANY SUGGESTIONS ??? in reply to Alberta Mike, 03-01-2001 16:59:44
Hi Mike, For best adhesion aluminum should be cleaned with phosphoric acid prior to painting(Alumi-Prep is a popular brand). It will be available from an automotive or industrial paint supplier. If you really want to do the job, a follow-up with chromic acid(Alodine is a popular brand) leaves the surface less corrosion proned(and yellow). Use a zinc-chromate primer. I like the "DP" series of epoxy primers from PPG, or the "Variprime" etching epoxy primer form Dupont. For most jobs I use the Dupont on aluminum, but both of these prmers are outstanding. The self etch is good, but it does not eliminate the need for acid cleaning. You can paint over either one of these primers with any kind of paint you're likely to find. Read the directions, DON'T BREATH IT, and don't get it on you. If you wait too long after priming you will have to sand before painting, otherwise no special tricks. If you decide you'd rather not mess with epoxy primer, you are still looking for a zinc-chromate primer. Good luck...Al English
Nathan(GA)
03-01-2001 20:21:21
 Re: Re: Prepping aluminum for painting - ANY SUGGESTIONS ??? in reply to Al English, 03-01-2001 18:21:29
Hey Al, I hate to change the material here, but do you know anything about painting plastic? I primed and painted some plastic martin gourds with spray can paint. It didn't stay on a year.
The gourds let too much light in, so the paint is just a cover to block the sun. The martins prefer it dark or cool.
I've got some that my Uncle gave me that he painted several years ago. They still have paint on them, but he doesn't remember what kind it was.
Thanks, Nathan
Al English
03-01-2001 20:54:33
 Re: Re: Re: Prepping aluminum for painting - ANY SUGGESTIONS ??? in reply to Nathan(GA), 03-01-2001 20:21:21
Hi Nathan, There are special primers for plastic. They don't work on all types of plastic, but if your gourds were originally painted, we can assume they are made of paintable plastic. Once the parts are primed, you can put whatever type of paint you want over it. I've tried a couple of hardware store type spray cans of plastic primer, but the one I use comes from an auto paint store. The auto paint store stuff is MUCH better. It's been a while since I bought any, and I can't remember the name of it. I know it is available in both bulk and in spray cans. I think I still have part of a quart so I'll check & let you know what it's called. If nothing else it will give you a place to start. When going to the auto paint store make it clear you are not priming flexible bumper covers. The product you want is made for priming plastic interior trim parts. Also, it helps to scuff up the surface with a fine scotch-brite pad before priming. Some plastics just don't hold paint very well, but hopefully yours will. Good luck...Al English
Al English
03-02-2001 18:09:14
 Re: Re: Re: Re: Prepping aluminum for painting - ANY SUGGESTIONS ??? in reply to Al English, 03-01-2001 20:54:33
Hey Nathan, I got the info on the plastic primer. It is made by Dupont and the product number is 2322S. Paint can be applied directly over it. Unless you're going to use the highest grades of epoxy or urethane enamel, paint durability will vary from color to color. Automotive paint would be the most durable. Dupli-Color spray isn't as good as bulk paint, but it's pretty good. Krylon holds up for several years outside. Rustoleum doesn't seem to last quite as long. The only thing that could be a problem is if your plastic is one that can't be painted. Hope this works out. If you need misquotes for your Martins to eat, I'd be happy to send you some...Al English
