Tool Talk Discussion Forum
If it's US made . . .
John Garner
03-25-2006 10:00:11
There are only two factories making files in the US, the Cooper (Nicholson) plant in Apex, North Carolina and the Simonds plant in Newcomerstown, Ohio. Both companies make files marked with their own brand names and private-labelled for others to sell.
Cooper also imports hand files from Brazil that they sell under their Diamond Tool brand.
As for file cards . . . DON'T! The spring-tempered wire bristles destroy a file's cutting edges. Use a file BRUSH, or some other sort of nylon-bristle brush to clean the loose stuff off of a file.
Junk that sticks between the file teeth can usually be scraped out with a homemade hardwood or Plexiglass scraper that looks like the blade of a wood chisel. Set the edge of the wedge perpendicular to the file teeth, and push the wedge down and along the teeth. A piece of junk that's really stuck can be scraped out with the point of a scriber or a sewing needle.
John
