Tool Talk Discussion Forum
Trailer Ramps
Grub0927
03-24-2006 19:48:28
I need to build a set of ramps to load my tractor and mower (4000#) on the 16' flatbed. The deck is about 22" above the ground and I have a spot under the deck to store ramps 5' long. I've thought about using 3" channel iron for the sides of the ramp and 2"angle iron for the cross pieces- sort of a ladder type rig. Would this be strong enough yet not so heavy that I'd lose a nut moving them? Am I overbuilding this?
Thanks in advance for your input.
(Muddy)Grub
Scott#3
03-27-2006 10:30:44
 Re: Trailer Ramps in reply to Grub0927, 03-24-2006 19:48:28
The ramps for my trailer are ladder style with 2" square tube rails and cross pieces from channel, 3" flat stock welded across one end allows them to lock into a rail on the trailer so they can be positioned at any width; they are plenty strong for loading 4,000 lbs, and not to heavy. They slide into pockets under the deck.
Scott
wdtom
03-26-2006 17:41:50
The ramps you are thinking of building are about like the ones that came with my trailer. They are about all I want to handle, and over built in my opinion. Good ramps though, no doubt. What I built is pressure treated wood ramps, same length, as wide and as high as will fit in the storage slots in my trailer. I sawed them out of 2x8s. there are 5 to each ramp, 3 1/4" wide/high with spacers between them. they are tied together with 3/8 threaded rod in 3 places, near ends, and in middle. the spacers are the right thickness to make the finished ramp the maximum width to fit in storage. So far they have loaded my 3500 lbs tractor with no problems. They are half the weight of the steel ones, which I keep and would get out if I had reason to someday.
JT
03-25-2006 07:57:49
If you are only looking at 4K, you can buy a set of Aluminum ramps for 2-300.00. I have a set that are about 55" long, rated at 10K for the pair, I have loaded a 504 International on my trailer with these ramps.
Jim
Richard H.
03-25-2006 05:58:55
I built my trailer with a dove tail and with 5ft. ramps that pivot and stand during transport. I used 4in. C-iron and 2x2x1/4 angle for ladder and the stiff legs. Three in. would probably work for the rails but hey, I had 4in. and used it. The key for me is, all I got to worry about is steering and not collasping the ramps. RH
ex-racer
03-25-2006 03:42:23
I used ladder construction - 1" square tubing with expanded metal (mesh) on top, and a "tension truss" made of 1/2" rebar underneath. Nice and light to handle.
Ed
Stan in Oly, WA
03-24-2006 23:26:31
Make a couple of steel braces with feet and provide a simple way of attaching them under the middle of the main structural members of the ramp. The strength benefit of effectively cutting the load bearing span in half will be considerable.
All the best, Stan
old
03-24-2006 20:07:41
The ones we use on a 16 foot trailor are made from 2X2 angle iron and a ladder type. They do have a little bow to them now but we have loaded 30-40 tractors with them. One thing that would be nice is a way to keep the rear of the trailor from droping down when you start up the trailor but other then that they work just fine
JMS/MN
03-25-2006 18:28:42
 Re: Trailer Ramps in reply to old, 03-24-2006 20:07:41
I had a 16 foot tandem trailer and added 2 feet of sloped beavertail. Made the ramps out of 3 inch channel and 2x2 by 1/4 crosspieces. Ramps pivot on 1 inch shaft, can slide sideways as well. On the bottom side of the ramps top end- the pivot- I welded outside legs and crosspiece that contacts the ground when loading on the trailer. Key to this working properly is this- the feet need to be angled FORWARD to the ground, so the foot rests on the ground AHEAD of the pivot bar. If is behind and the trailer is not hooked to a tow vehicle, the ramps collapses and the trailer front comes off the ground. Each ramp has its own pivot bar so they are easy to remove, and to haul tricycle tractors, I made another ramp with the top ends cut into a U, and just rest it over the two pivot bars.
