Wannabe weldor needs welder advice
Tibor
03-01-2001 09:52:25
I'm planning several projects for my jeep. Rear bumper/tire carrier, skid plates, braces, corner guards, etc. Mostly using mild steel in 1/8 - 1/4 thickness. I'm looking for the most cost effective and simplest process to use for this kind of application preferably in 110V. What kind of welder do I need? AC, AC/DC stick, MIG or wire/flux? I'm also going to take some courses in welding but not till the summer unfortunately. I'd like to get started with these projects sooner. Maybe I can find someone local to show me some basics. Thanks for all the advice.
T_Bone
03-02-2001 05:41:44
 Re: Wannabe weldor needs welder advice in reply to Tibor, 03-01-2001 09:52:25
Hi Tibor, I would wait until you get finished with Vo-Tech to make up your mind. You will have a better understanding of what you need.
T_Bone
DubyaDee
03-02-2001 04:38:58
It is surprising how much can be done with household current, cheap, low duty cycle, stick welders if that is all you have. They will handle 1/8" mild steel projects if you are willing to weld and wait.
Steve
03-01-2001 17:15:30
I have seen some of that done with a 110 volt Hobart wire welder using co25 gas. Beveling with a grinder and making several passes he did a good job for us. I used to drive a bulk feed truck and we needed a hitch welded on the back to pull a flat bed trailer to haul bulk feeders and panels and some sack feed on. That hitch went thru heck pulling it thru some of those ruff hilly pastures down around Rocksprings Texas. As far as I know it's still on there. Hope this helps,Steve
