How to drill 316W stainless
Dave Mischler
12-01-1998 19:44:32
I have some type 316w stainless steel tubing that needs some 3/16 holes drilled. I broke a cobalt bit on this stuff, and barely scratched it. How do I drill this stuff? I considered getting a carbide cutter for the old Dremel tool, but I haven't tried it yet. Any ideas appreciated.
John Pullman
12-05-1998 13:41:21
 Re: How to drill 316W stainless in reply to Dave Mischler, 12-01-1998 19:44:32
Get a decent (but cheap) 3/16 carbide masonary bit. Also buy a fine grit HARD grinding wheel for your bench grinder.
The masonary bit will work just fine if you first sharpen it carefully and apply moderate pressure in the drill press.
I've drilled out frozen allen socket set screws from old sheaves with the bits out of my hammer-drill set. Also an added benifit is that the bits drill concrete faster when real sharp! If you can afford a real green stone wheel for sharpening carbide do that. Good luck John
Amos
12-03-1998 10:26:47
We use good quality bits and good cutting oil
frank
01-02-1999 17:58:52
 Re: Re: How to drill 316W stainless in reply to Amos, 12-03-1998 10:26:47
: : We use good quality bits and good cutting oil
Years ago in the USAF a japanese guy showed me that by sharping the drill with a lot of lead, about 60 degrees,you could drill stainless no problem
