Hi Scott, For welding there's two good choices. Tig with 75%He25%Ar cover gas using DCEN for a porosity free weldment. With 100%Ar or other gas mixs you will get some porosity with-in the weldment but you can keep filling pin holes until you get a clean surface enough to polish to a mirror finish without defects if your patient. Second process would be O/A with a very slight reducing flame (carbonizing flame). Error on a reducing flame rather than a oxidizing flame. Keep your filler rod always loacated with-in the flame to keep the rod from oxidizing. Both pices will need to be center beveled as this will make a strong joint after welding but more important allow for a good cover pass for finishing. After beveling then brush to clean base metal with a new SS wire brush before welding. Clean your filler rod with emery paper then wear gloves to keep from contamiating the rod surface with oil from your skin. For a exact color match, use filler rod made from your base metal stock. Cut thin (pre-cleaned) strips about 1/16" in thickness and width. You will not need to use a flux with either weld process. The next best filler rod would be solid #14 electrical wire but it will not color match exactly. A piece of Aluminum or SS flatbar works great as a chill bar for pre-tacking as the CU will not stick to either one. You could also use a mortise and tennon joint with CU pins flinished flushed rather than welding or make a carved center piece joining the two wings of the cross. You can make the pins using the draw plate method. Using silver solder would leave a light gold color on silver look to the joint. T_Bone
