Spot weld removal
Mike
02-26-2001 14:11:09
Need to move tin centers on wheel, spot welds are an inch by 3/8 oval. Can't decide how to remove w/o sacrificing either the center or the rim. 8 spots times 2 wheels. Any suggestions appreciated. Thanks, Mike
Steve U.S. Alloys
02-27-2001 05:22:12
 Re: spot weld removal in reply to Mike, 02-26-2001 14:11:09
You can use an airless gouging electrode to scarf them of or pierce them Mike. Either or. They work well on AC buzz boxes. Mine or anyone else's.
Franz
02-26-2001 18:39:13
Two ways to do it, Dewalt among others make a slug cutter that's a lot like a heavy duty hole saw, mounted on a magnetic drill press. It worls very well for cutting out large spot welds.
The second way is to gouge them out with a plazma cutter.
If you don't have access to either machine, use a large center drill to drill 3 holes removing the entire weld.
ltf in nc
02-26-2001 16:06:02
I would try to drill 3 each 3/8" blind holes in series in each spot weld.
