Tool Talk Discussion Forum
Welding sea containers
Robert Spence
03-15-2006 20:18:05
I want to put an overhead door in a 40 foot sea container...It will be a welded steel frame that I will make up and plasma cut the container.
I tried welding on one of those before and it seemed a little hard to do for some reason.Is it the steel type or what?
Maybee I should Mig weld it ?
Anyone do much on these containers?
RJ-AZ
03-17-2006 20:07:31
 Re: Welding sea containers in reply to Robert Spence, 03-15-2006 20:18:05
I used flux core MIG to weld in shelves in my 20 footer. I also cutin a hole for a wind turbine vent with my oxy-acet torch with no problems. Best little shop I have seen. Just a temp till my new one is done in OH ABOUT TEN YEARS.
Slowpoke
03-17-2006 02:24:21
Find a rental place that rents storage space in containers to the public. They cut openings and weld in overhead doors in the sides and divide the containers into 2-3-4 small sections. Ask if you can see how the work was done. I never buy from dealers, their overhead is too high. I look for containers that "have to be moved tomorrow". Stores and businesses closing need to get the things off the property especially if they lease the property. Keep looking and if you see a container ASK if it's is being used. It took me six months of keeping in contact with a store that finally went out of business. Got the 40' box for $900. BTW, I would not buy a 20' box since a 40' is only $200-$300 more and shipping is the same cost. West coast trucking is $75-$90/hour. Use a trucker with a Landoll trailer, made for moving containers. I would keep the original doors if the box was out somewhere away from view. Install a box over the lock to keep lock cutters out. Use a Master lock or similar with 7/16" shackle. "The voice of experience".
T_Bone
03-17-2006 01:12:25
Hi Robert,
I've never welded on containers but have worked with Corten coated metal. I'm not 100% positive how the CT coating in applied, electrolysis ?, but the base metal prep is very important for welding.
Use a 100grit sanding disc to remove the CT and not a grinding wheel. Why? Because the CT penetrates the base metal more than like (example) galvanized and if you attempt to grind the CT off it will fold over into the valleys of the surface grain then ridges get pushed over onto the the next valley thus trapping the CT. Then when you apply the molten puddle the CT explodes into fumes thus causes porosity with-in the weld. Using a sanding disc helps stops this process.
The base metal surface will look something like this ^^^^^^^^^^^^^^^^^ with ridges and valleys.
Mig would also be a poor choice for welding CT as you will never remove 100% of the CT coating from the weld zone.
SMAW would be the best process with a 6010 or 6011 as the electrode of choice.
T_Bone
R Spence
03-16-2006 14:06:54
Thanks for all the great advice. I am going to use the Plasma cutter and Mig weld if the wind stays down.
RB/CT
03-16-2006 13:33:53
Check out www.aaronsupreme.com, look under specials and you will see a new twenty footer for $2450. I bought one 4 years ago for $1700 from another company. I opted for a new one, (actually made one full trip from China) and am 110 percent satisfied. No permits, no taxes, no maintainance. Only threat is that someone could remove it full of contents and steal the container and whats inside. Weighs 5500 lbs, and could be stacked 8 high, 400,000 lbs total. Well built (overbuilt) and always with a good resale value as steel keeps going up. Mine is Cor-Ten steel. Good luck.
RB/CT
03-16-2006 13:40:08
 Re: Welding sea containers in reply to RB/CT, 03-16-2006 13:33:53
Sorry oops made a mistake new 20 footer is $3450. Real bang for the buck with these items.
Luke S
03-16-2006 14:50:44
 Re: Welding sea containers in reply to RB/CT, 03-16-2006 13:40:08
Check out ebay for these containers. They have some for a little over a grand! 40 footers even.
CaptRon
03-16-2006 08:37:40
I've hauled 100's of containers to and from repair yards thoughout the southeast and each yard had at least 5 guys burning and welding on them. There are published specs on the proper repairs and type of welding processes to be used. I've always seen stick welding used only but don't know what rod they are using. I welded some brackets in a 40' storage container using 6011 several years ago.
Since you are not looking to certify the container for international trade then you can use any process that you feel comfortable with. Actually, flux cored mig would be fine and quicker than stick. Also you don't have to worry about the wind blowing away the shielding gas.
Capt Ron
Rauville
03-16-2006 05:30:46
Hi;
If they are made from true Cor-Ten, which is designed as weathering steel, probably E8018 would be the recommended stick rod.
On the other hand, I'm sure there are a lot of them made overseas from who knows what...?
Good Luck
will, Tx.mn.
03-16-2006 04:05:25
Hello,
i'm curious,like where does one purchase one of these containers? as i've heard they are a good storage place as they are definetly a good roof for ones' stuff.. and are they expensive? i suppose they are cuz now the price of steel is way up (i wonder whom is to blame for that)
Thanks for your help
Will
Slowpoke
03-17-2006 23:43:11
 Re: Welding sea containers in reply to will, Tx.mn., 03-16-2006 04:05:25
Will, see my post above. Be sure to make a good inspection of the one your getting before paying (unless you're buying new....$$$$$). I've seen them with so many holes in the roof that it looks like stars in the sky. (Dealer sales.)
Joe(TX)
03-16-2006 15:42:30
I see them for sale all around fort worth. Lots of ads in the equipment trader.
wesd
03-16-2006 07:59:45
Here's a link to a company in Kansas that sells these containers. This will give you an idea of what's available and a ball park figure on cost. I'm sure there are many places around the U.S. that sells them.
CBBC
03-16-2006 07:51:15
Here on the west coast, (Vancouver BC area) there are lots for sale. I gather that the containers come here from asia full, then get put into storage yards to wait until someone wants one to fill and send back. These yards have got very full over the past 5 years.
Eventually they have to start selling them off for space. The last one we bought was a 40' can for about $2000 CDN. The price has probably gone up since then.
I'm sure that the other port cities also have the storage yards.
Grant
Slowpoke
03-17-2006 23:34:11
 Re: Welding sea containers in reply to CBBC, 03-16-2006 07:51:15
There are about 9 million containers world wide.
Average use is ten years.
CBBC
03-15-2006 21:13:36
Hi Robert, I believe they are made of Coreten (core -10 ? ) steel. I don't know what that is but I have done lots of cutting and welding on them, both mig and stick.
I found that 6013 worked well( I don't perticularly like 7014 and 7018 but was told they work fine). The mig was good also, but I was outside and limited by wind. If you mig, clean the area good with a wire wheel, that paint is really thick and tough and probably toxic when it burns.
Grant
